Grinding the Fender!!!!
Old Nov 15, 2005 | 04:57 PM
dragondesigns's Avatar
Default Grinding the Fender!!!!
anyone know what the most effective tool I can use to cut the metal so I can put in a One-Piece headlight in place of my current Two-Piece? Would a dremel work or would I need something stronger????
Old Nov 15, 2005 | 05:00 PM
VB05's Avatar
Default RE: Grinding the Fender!!!!
dremel should be fine...when u do it let me kno how hard it was and how well they fit, cause im considering this mod myself.
Old Nov 15, 2005 | 05:03 PM
Yeah, I'll try the dremel. It doesn't seem too hard. My biggest concern is not grinding the metal, but re-wiring the new headlights.
Old Nov 15, 2005 | 05:05 PM
I just hope that I don't f*ck it up! []
Old Nov 15, 2005 | 05:35 PM
Jestnomen's Avatar
6th Gear
Don't worry, wiring the headlights is fairly easy. Did you get the rewiring kit?
Old Nov 15, 2005 | 06:58 PM
sandman's Avatar
https://www.audiforums.com/m_149303/tm.htm
a dremmel will take a while. i used a zawzall. your best friend will be an angle grinder though because the original cut wont be perfect and it will take some patients to get it to fit perfect.
Old Nov 15, 2005 | 08:03 PM
Where do I get the rewiring kit from??
Old Nov 15, 2005 | 08:14 PM
Is this all I need (as far as wiring is concerned)?
[IMG]local://upfiles/11465/9E436DE16130409DB3B0C77EAA9E202C.jpg[/IMG]
Old Nov 15, 2005 | 08:29 PM
When I purchase my projectors, is it a good idea to re-seal the seams with a sealant to help prevent any possible leakage??????????
Old Nov 16, 2005 | 12:14 AM
BFlan2001's Avatar
yes, that is the only wiring you will need. no, you dont have to reseal your nwe headlights, but it might be a good idea if you get the cheap ebay ones. i used a dremel and it took maybe 15 minutes for both sides.
