Grinding the Fender!!!!
anyone know what the most effective tool I can use to cut the metal so I can put in a One-Piece headlight in place of my current Two-Piece? Would a dremel work or would I need something stronger????
https://www.audiforums.com/m_149303/tm.htm
a dremmel will take a while. i used a zawzall. your best friend will be an angle grinder though because the original cut wont be perfect and it will take some patients to get it to fit perfect.
yes, that is the only wiring you will need. no, you dont have to reseal your nwe headlights, but it might be a good idea if you get the cheap ebay ones. i used a dremel and it took maybe 15 minutes for both sides.
