GTRS intalled Problems inside...
Old Apr 27, 2007 | 03:45 AM
  #21
gotaudi's Avatar
Default RE: GTRS intalled Problems inside...
alright I moved cylinder 2 injector to 1 and 3 to 4... before i was only seeing misfires at idle on cylinders 2 & 3, once i moved the injectors the misfires moved with them. their were no misfires on 2 & 3 but misfires on 1 & 4.... so I think it is safe to say that the injectors are bad....
Old Apr 27, 2007 | 05:10 AM
  #22
cincyTT's Avatar
I'm make believe
get some genesis injectors, far better.
Old Apr 27, 2007 | 06:34 AM
  #23
gotaudi's Avatar
okay I went and logged the car, and this is what I found: The ecu requests a lambda value of .90 (13.2:1)till about 4500RPM's then the lambda goes down from their and requests .82(12:1) at about 6000RPM's this still seems lean to me... but what do I know?
I tried to take it to redline but I such at shifting, and the rpm's come faster than normal (I went from stock to BT ) I am going to get new injectors but I think the AFR seems to be "slow"... should it be like this or should it be different?
Old Apr 27, 2007 | 10:24 AM
  #24
dafrazi's Avatar
ORIGINAL: gotaudi
I have a 3in MAF so I have .25" bigger MAF than yours so more air car go through it...
I see now.
The larger housing is lettingair go by the sensor unmetered; thereby, givinglow readings at the MAF sensor. Unitronicsthen adjusts their fuel maps toaccount for this unmetered air.
Old Apr 27, 2007 | 10:59 AM
  #25
BaconBait's Avatar
Unitronics usually tunes forafuel pressure of4 bar. You may want to contact them and make sure it's set correctly.
Old Apr 27, 2007 | 11:34 AM
  #26
akielb's Avatar
God, I love it when people figure this crap out. Where you on stock injectors?
Old Apr 27, 2007 | 01:57 PM
  #27
cincyTT's Avatar
I'm make believe
he had 440 green tops, you not read the thread?
You can increase fueling via lemingwinks,with the fuel tweek. Also uni has a new setup like limingwinks that can be downloaded in the 1.8t section on vortex to do the same thing.
gotaudi
Feb 21, 2008 01:54 PM
NuYorka103185
Dec 20, 2007 09:12 PM
gotaudi
May 20, 2007 08:34 PM
mlo517
Jul 29, 2005 02:37 AM
