Guage cluster light came on?
Old Jun 29, 2005 | 03:11 AM
AfourSquat's Avatar
Default Guage cluster light came on?
I have a 98 A4 2.8 which I've owned for about 2months now. I've already had the digital display crap out on me since I've owned the car. When I bought it, it had 72K on it. I've only put about 1K since then. Today when I started it up, I had an orange light in the RPM guage pop up, and looks like a water faucet with a lightning bolt throught it with the words 'check.' The temp guage and oil temp were both reading normal so I just assumed it was malfunctioning like I've had w/ previous cars. Can anyone tlel me if this is the coolant or oil guage, and whether I should be concerned about ? BTW, I plan on taking my car to have the the oil changed as well as the T-belt changed within the month. Thanks for thelp and the suggestions are appreciated.
Old Jun 29, 2005 | 05:23 PM
Karl's Avatar
Default RE: Guage cluster light came on?
Go ahead and invest in VAG-COM.. or find somebody that has one... see if you pull any codes. If no codes are found, then its a faulty guage. most likely not though
Old Jun 29, 2005 | 08:13 PM
AfourSquat's Avatar
I called the Stealership to set up a time to have the oil changed and the light diagnosed. I explained the light to the guy on the phone and told him my other engine temp and oil temp guage were both normal. He told me to just make sure all the fluids, coolant esp. are all topped off. Where is the coolant resoirver take located on my 98 A4 so I can check it out? Thanks for the help.
Old Jun 29, 2005 | 10:05 PM
Nasty's Avatar
go to auto zone, they will pull the codes for free. dealership will rape you
jayj93pgt
May 14, 2009 01:22 PM
afstud6900
Oct 13, 2008 10:08 PM
sdboarder84
Jan 24, 2008 09:03 PM
toyolla86
May 4, 2006 02:11 PM
D5buddy408
Apr 7, 2006 01:42 AM
