gutted cat vs test pipe????
Old Apr 11, 2006 | 10:50 PM
02A4_B6's Avatar
Default gutted cat vs test pipe????
2002 AUDI A4 1.8T QUATTRO
does anyone know if there's a big difference between installing a test pipe or if i just gut the cat? will the power gain and results be the same? would u still be able to pass emissions with a test pipe or gutted cat? thank you for your input
Old Apr 11, 2006 | 10:53 PM
tip5's Avatar
Default RE: gutted cat vs test pipe????
No your not going to pass emisions with either.. I suggest a testpipe over a gutted cat. But if your low on money and want the engine bay to look stock gut it.
Old Apr 11, 2006 | 11:00 PM
cary12's Avatar
My cats are being replaced at the stealership right now along with my Mass Air Flow sensor. Why are you wanting to do this? If the CAT is bad, Audi will replace it up to 77,000 miles.
Will I notice a change in performance for the better after the CATS and the sensor is replaced?
Old Apr 11, 2006 | 11:05 PM
BadLuckAudi's Avatar
No replacing the cats probably wont give you much more performance wise but gutting them or a test pipe is supposed to give you an extra 10 hp or some with faster spoolup
powersmokin
Apr 10, 2008 10:49 AM
The Bishop
Nov 30, 2006 06:03 PM
Hanestyle
Oct 24, 2006 04:07 AM
Mythstery
Jan 19, 2006 08:17 PM
greenday
Nov 29, 2005 03:43 PM
