Has anyone had this before?????????????????????????
Old Jun 27, 2005 | 11:30 AM
lidonnit's Avatar
Default Has anyone had this before?????????????????????????
I seem to have lost oil pressure...... The pride & Joy is ill.
I have so far dropped the oil pantaken oil pump off & it all looks good. I cleaned out the pick up, not enought there to block anything up. Changed oil filter & everything... No change... It appears there is no oil getting to top end?
Old Jun 27, 2005 | 11:45 AM
CRAZYHAWK's Avatar
Default RE: Has anyone had this before?????????????????????????
Is the oil pump working? Could be a blocked passage to the valve area.
Old Jun 27, 2005 | 03:59 PM
Mr_You's Avatar
Though I'm a newbie, from what I have read if you are experiencing an oil sludge problem you will want to go through a cleaning cycle ASAP (check other threads and other forums) in order to bring it back to factory specs.
I'm planning on having an oil pressure check next oil change to check the status of potential sludge.
