having a problem with 96 A4
Old Aug 31, 2006 | 01:06 AM
audiandajeep's Avatar
Default having a problem with 96 A4
i cant get into my car. the keypad for the alarm system will not unlock the doors, and i cant use the key to get in. this is the second time in 2 weeks that this has happened, i went to audi and got a new battery for the keypad, everything went back to normal. i got home from school this afternoon locked up the whip, and went back out about 2 hours later and the keypad wont work.... suggestions, ideas, anyone know what the hell is going on???
Old Aug 31, 2006 | 03:41 AM
ADubyaD's Avatar
SoCal Crew Member
Default RE: having a problem with 96 A4
hmmm, why wont key work? if you can get into the car, you can reprogram your remote by doing this
turn on car but do not start engine..
leave key in and car on and get out
close the door and lock the car
hold both remote buttons for like 5 seconds till the car beeps.. this should make the remote work
good luck
Old Aug 31, 2006 | 04:08 AM
BadLuckAudi's Avatar
no you do that and press lock once on the first and twice one the second or at least thats how my 99.5 works
ORIGINAL: ADubyaD
good luck
Old Aug 31, 2006 | 04:19 AM
i put the key in the door and it wont turn, i assume its an anti theft thing but i dont know. i just know its really a pain in the *** to not be able to get into my car... has this happened to anyone else??? i wonder if maybe my car battery is going bad, but dont think the car alarm draws that many amps that it would stop the car from unlocking due to a bad battery.
it would be great to reset the alarm keys but i cant get into the car at all.
Old Aug 31, 2006 | 04:49 AM
hmm thats wierd maybe the door lock is Flucked up Mine did that once but instead of not turning it turned and turned forever and never did anything and it was like $280 to replace the lock assembly
Old Aug 31, 2006 | 10:56 PM
ADubyaD's Avatar
SoCal Crew Member
try the other key... you have 2 keys i assume?( my 96 has 2 different keys, 1 door and glove and one ignition) and try turining the other way, give it a little pressure
and badluck i think the systems on 96's are diff, mine works how i said but my moms 01 1.8 works like you said
Christopher Nemitz
Mar 12, 2012 09:02 PM
jimc137
Mar 9, 2011 06:48 PM
spyrosg7
Apr 4, 2010 07:48 PM
RIA6
Nov 30, 2006 09:06 PM
