headlamp washers
Old Feb 8, 2005 | 06:39 PM
thintzen's Avatar
Default headlamp washers
does anyone have any problems with their headlamp washers? mine dont work but if i were to play with themmanually, pulling them up and down i notice that fluid is escaping through the pump? also if i full up with washer fluid, eventually there will be a puddle on the floor when it passes the pump?
how can i fix this, and how doi know if its the pump and not the nozzles?
Old Feb 8, 2005 | 06:59 PM
dudley doright's Avatar
Default RE: headlamp washers
ORIGINAL: thintzen
Have someone go in the car and turn the headlamps ON and pull the wiper lever towards him/her. Does it spray?
Old Feb 8, 2005 | 07:28 PM
Jestnomen's Avatar
6th Gear
I had the exact same problem. I replaced the washer pump and the headlight pump and everything was fine.
Old Feb 10, 2005 | 03:31 AM
apg96's Avatar
why would u ever actually ned to use them? I used mine once to see if they work and have never used them since.
Old Feb 10, 2005 | 05:17 AM
BFlan's Avatar
do they automatically come on when you spray the windshield? where is the button, or switch, or whatever the hell it is that turns them on?
Old Feb 10, 2005 | 09:23 AM
jason745's Avatar
They automatically come on when your lights are on and you spray the windshield.
Old Feb 10, 2005 | 02:33 PM
a224932's Avatar
I thought my headlight washers did not work till I found out the following. They only work with the following conditions:
A. You have your headlights on
B. You hold the washer stalk for about 5 seconds
C. It is 40 degrees F or cooler outside
When all three conditions are met, they work like a charm. Let me know if this works for you.
Old Feb 10, 2005 | 07:45 PM
Jestnomen's Avatar
6th Gear
I agree with A and B, but C is wrong. It is not temperature dependant.
Old Feb 12, 2005 | 01:30 AM
david9999's Avatar
Agree. It isn't temperature dependent. I've gotten sick of looking at the yellow fountain in the middle of my display. I broke down and bought a used one from Dad's Auto. Install is tomorrow.
BoostedA4
Apr 2, 2011 02:21 AM
thintzen
Jun 9, 2010 11:55 AM
wolfgang51
Dec 27, 2009 03:09 PM
mstout
Jul 27, 2008 12:12 AM
miabhai_freaked
Feb 14, 2006 09:08 PM
