Headlight Adjustments????
I recently brought my 04 1.8T in to have PIAA H7 bulbs placed in...but when they put them in....i think they might have moved the vertical adjustments on the alignment of the lights. Is there anyone out there that can help me in this problem???[&:]
ehhh so pop your hood and move the big white adjustment screw on the backside of the headlights. There should be two of them, one for verticle movement, one for horizontal. I'll leave you to figure the rest out.
there are two screws in the top of the housings, if you go the passenger side and look through the air intake, there is a hole in the plasic... put a flat head screw driver down in there and start turning, you will see your headlight moving, do the same on the other side... NOTE: there are two screws, one for the highbeam and the other for the lowbeam...
