Headlight Removal Write Up?
Removing and installing headlights
WARNING[/align]
Always disconnect the battery earth strap before working on parts of the gas discharge headlights marked with yellow high-voltage warning symbols.
Removing
Headlight (left-side):
With ignition switched off, disconnect earth cable at battery
Detach cover (left-side) -1- in engine compartment.
Headlight (right-side):
Detach cover (right-side) -1- in engine compartment.
Unscrew bolts -arrows-.
If fitted, detach activated charcoal filter solenoid valve 1 -N80--item1- at air duct.
Remove air duct -2-.
Both sides (continued):
Use adhesive tape to mask area beneath headlight to prevent damage to paintwork.
Unscrew bolts -1- and -5-.
Loosen bolts -2- and -4- a few turns but do NOT unscrew completely.
If fitted, cut through cable tie.
Unplug electrical connector -3-.
Remove headlight from body towards front.
Installing
Installation is carried out in the reverse order; note the following:
Check whether vent element has been inserted on underside of headlight.
Slide headlight horizontally onto lower headlight mounting as far as it will go.
Position stop screw -1- so that it makes contact with lock carrier.
Use stop screw to align headlight with body contours (gap widths).
Note[/align]
Pay attention to area around wing panel opening when aligning headlight.
Tighten bolts -2...5-.
Connect the battery. Additional steps required.
Following installation, adjust headlights.
Tightening torque
Component
Nm
Headlight to lock carrier
[IMG]local://upfiles/12092/23CEB132A5C049378FCC7941ED1EAD9B.jpg[/IMG]
[IMG]local://upfiles/12092/6F66B44FAD68408AABA404E8096D885C.jpg[/IMG]
[IMG]local://upfiles/12092/4D575CEA862344DEAD1127B9CC3B60FA.jpg[/IMG]
[IMG]local://upfiles/12092/1E4FE861134A4AE6BBE83212D8064F6B.jpg[/IMG]
[IMG]local://upfiles/12092/C19B4669DE6D4A04936EA0CE91C16AE2.jpg[/IMG]
Techbod,
Great step by step. Kind of a daunting task when you don't know where to begin but a piece of cake when you learn that those head lamps are easily pulled out.
Thanks for the help.
