Headlight washers keep blowing fuse
Old Feb 18, 2007 | 04:24 AM
MrAceXPS's Avatar
Default Headlight washers keep blowing fuse
During our last snow and ice storm, my winshield washer system died. The wiper blades worked, but the winshield sprayer failed.
Upon inspection, the fuse blew. I replaced the fuse and got the winshield sprayer to work, but if I turn the headlights on, which would allow the headlight sprayers to work, the fuse blows when I turn on the sprayers.
The tech at the Audi dealer said they could have frozen down, but I don't see why they would stay that way, as I park in a garage.
He also said the pump could be failing.
I am out of warranty so I am not eager to bring it in for repair. Is there any way to troubleshoot this? Thanks!
Old Feb 18, 2007 | 01:38 PM
david9999's Avatar
Default RE: Headlight washers keep blowing fuse
Sounds like the pump for the headlight washer. You can either disconnect the pump, replace it,
Old Feb 18, 2007 | 03:04 PM
MrAceXPS's Avatar
Is the pump easy to replace? A do it yourself job?
How would I disconnect it?
Thanks for your help!
Old Feb 18, 2007 | 06:47 PM
AudiTurbo's Avatar
I was going through the same problem. Just wait until it warms up a bit
v8ramair
B7 Models
May 23, 2012 12:16 PM
Mojo3
Mar 24, 2012 03:08 PM
zooyork182
Feb 5, 2011 10:31 PM
rob1
Feb 20, 2009 12:07 PM
