Headlights and Fog Lights do not work
Old Dec 8, 2006 | 09:16 PM
Deb38's Avatar
Default RE: Headlights and Fog Lights do not work
hhhmm similar issue for me...my fogs went out at the exact same time. haven't worked since.
Old Dec 10, 2006 | 10:15 PM
drewdq's Avatar
Well I decided to follow this guide to try and fix the switch:
http://www.audiworld.com/tech/elec114.shtml
Of course nothing goes easy and I stripped one of the torx screw to take out the airbag. No big deal...I got a screw extractor thinking it would be a piece of cake to get the screw out. The problem is that snapped off inside. I manged to drill another hole to start another screw extractor. Figures, that one stripped.
Anyone know of a good screw extractor (easy out), because apparently oem industrial brand and black and decker suck.
Old Dec 10, 2006 | 10:33 PM
QuattroChucko's Avatar
ORIGINAL: MilitantGrunt
Its the whole stalk.. I had the same problem a month ago, do your yellow corners turn on?
If they do but not the headlights then its the stalk that controls the headlights/ turn signal switch. Its a 170 dollar part, then another 60-100 (depending on labor I paid 60.. for private mech) to take off the air bag + steering wheel to install the damn thing.
You can get the stalk from ecs for 140, i just bought one last week
Old Dec 11, 2006 | 02:30 AM
Henderson03us's Avatar
ORIGINAL: rbrtech
do your wipers work? if not wiggle your key.
other scenerio is you have a faulty headlamp switch or a pain in the a** wiring problem
hey
i'm new here i actualy just joined tonight because my brothers headlights just stopped working tonight and i need to figure out whats wrong with them and rbrtech his windsheild wipers are not working and he says his heater is acting weird too not sure what that means but the car is not here so i can see for my self. just wondering it you think because the wiper aren't working too it might be the ingition switch verses the head light switch assembly?
thanks
jonathan
Old Dec 11, 2006 | 02:40 AM
Karl's Avatar
my very first post was this exact same problem.. its 99.9% likely that you need to replace your headlight switch..
Old Dec 11, 2006 | 02:42 AM
ok cool when i get to the car that will be the first thing i dig into thanks just checking to see if it might be something else so thanks i appresiate it i let you guys no if it works or doesn't
thanks
jonathan
Old Dec 12, 2006 | 12:57 AM
rbrtech's Avatar
henderson try wiggling the key. both of these ignintion spring and headlamp stalk are very common issues that have similar problems. if the key thing works take it into audi for the recall
Old Dec 12, 2006 | 10:54 PM
  #18
drewdq's Avatar
To get that bolt out that I broke 2 screw extractors on and stripped a third, I ended up JB welding a socket to it. It came right out the next day with a slight twist from a ratchet.
The stalk ended up being my issue. I just cleaned the contacts and messed around with it making sure it touched better. Thanks guys for all the help.
Old Dec 13, 2006 | 08:01 AM
  #19
johnw's Avatar
Hi, Im new to this forum and new to Audi! Slightly off subject, but how do I change the headlight bulbs in 2002 A4 and how do I know if I have xenon lights or not? Finally, the internal adjuster for headlights is at highest level and i still only light up a few feet in front of car, how can i raise the level of the lights? Thanks
hoovdiddy
Jul 5, 2017 10:19 AM
Pyromatic177
Mar 16, 2013 08:22 AM
Mark Newcomb
Dec 31, 2012 07:57 PM
gioinnj
May 6, 2010 10:32 AM
SuperSquid
Jan 20, 2009 10:04 PM
