HELP: big engine problem
Old Mar 14, 2006 | 11:07 PM
phroztbyt3's Avatar
Default HELP: big engine problem
So... let me tell my little story (its tiny dont worry).
I went to bestbuy. Bought some paper, and left the store. I autostarted my car and went inside..... my engine light was flashing. I didnt drive, I just waited for a second trying to get my head together. Then all of a sudden, the car starts vibrating up and down. So there is definitely something wrong with the engine. I called someone who knows a few things about cars. He thinks that one of the cylinders is malfunctioning. So I started driving home (what else to do ya know), btw its an automatic. It has a tough time switiching gears. I am going 40 basically stuck in 3rd.
Yes I restart the car a couple times and test out a few things.
So, I usually have an audi guy look at this stuff, but I believe he's on vacation. What do you think the problem is, can I do a simple fix for this, and if not, how much is the solution going to cost.
Thanks guys (Havent been here in a whiiillllllleeeee).
-Phrozt
Old Mar 14, 2006 | 11:12 PM
onepoint8tee's Avatar
Default RE: HELP: big engine problem
Consider a coil pack(s) or ICM.
Not to be mean, but if something bad happens because you drove it after seeing the CEL was flashing, you deserve it... You should know not to drive the car with a flashing CEL!!!! Shame on you...
Find someone who can vag it or rent a diag. tool from autozone or wherever before you drive it anymore.
Old Mar 14, 2006 | 11:27 PM
phroztbyt3's Avatar
well i am driving it as slow as possible... not trying to floor it ofcourse...i dont think anything else happened... but i really didnt have much of a choice... i wanted to atleast get it to my house (5 mins away from bestbuy). How much does an ICM or coilpack usually run?
Old Mar 14, 2006 | 11:31 PM
ORIGINAL: phroztbyt3
Check out ecartoys .com for any OEM parts youll ever need.. Most of the time youll be spending over $50 and shipping is free for orders over $50.. Coil pack should be around $22 and I think an ICM is around $80.... Make sure you get your codes pulled before you go purchasing anything of course. Dont drive it anymore seriously even if its 1 mph.
Old Mar 14, 2006 | 11:33 PM
phroztbyt3's Avatar
well then how do i get it 2 my body shop... the shop is literally about 7 mins away... and what.... should i get a tow truck... im not doin this at my house, thats for sure.
but yea.. thanks for the response
Old Mar 14, 2006 | 11:37 PM
RENT/BORROW A DIAGNOSTIC TOOL FROM AUTOZONE OR WHEREVER AND TAKE IT TO YOUR CAR TO SCAN! I dont know how much a body shop can do for you as this sounds like a mechanical problem and not a dinged fender.. Cant you get a ride to autozone to get the tool?? If not then yes get a tow truck because if you dont know exactly whats wrong with it and a flashing cel means DONT DRIVE/RUN IT.. "Pull over imediately and have your car towed to your nearest Audi dealer for service" as the all mighty manual says.
Old Mar 14, 2006 | 11:51 PM
phroztbyt3's Avatar
ah... icic... sry.. my bad not body shop... its audi dealer.... a friend of mine is a mechanic there. I guess Ill wait for his reply for what i should do with the car.. but thanks on finding the range I have to spend..... is this a common problem... cus it just happened out of the blue, like i never had an ACTUAL engine problem... only problems i had were electrical (cus Audi has many of them). But yeah, ofcourse I am not driving it now, so mad that it happened though.... o well.. thats life.
Old Mar 14, 2006 | 11:53 PM
good luck.
Old Mar 14, 2006 | 11:57 PM
phroztbyt3's Avatar
thanks again,
Ill post when its fixed... and we shall c if ur right about the problem... i trust these forums though, so atleast im semi relieved.
Old Mar 15, 2006 | 06:25 PM
phroztbyt3's Avatar
can someone please find me links to prices and buyer information on two parts
Audi a4 quattro 1.8t 1999
1. Coil Pack
2. ICM
that would be awsome... i've been looking for 2 hours now and I cant find the parts... im probably just not experienced or something.
Thanks guys.
