Hey guys, last night it was starting to rain so I ran outside and started the car up(99.5 a4 manual ft)I didnt let it warm up
and pulled it about 10 feet into my carport, this morning I headed out to go to work and it wont start.. it cranks and cranks but just wont fire.. any ideas? The battery light on the dash blinks while it is trying to turn over..
Any ideas would be appreciated
Thanks
Drew
and pulled it about 10 feet into my carport, this morning I headed out to go to work and it wont start.. it cranks and cranks but just wont fire.. any ideas? The battery light on the dash blinks while it is trying to turn over..Any ideas would be appreciated
Thanks
Drew
Quote:
Have you try to put it in a gear and pop start?
Yeah, try that....it should work. Have you try to put it in a gear and pop start?
Another thing to try is to (don't recommend unless last resort) spray something with a hydrocarbon base into your engine then try to crank it....i.e. carb cleaner, brake cleaner....etc.
RE: Help! Car won't start
Or ether.
Either no spark, or no fuel.
If you spray ether in the throttle body, hook it up and it starts, then you have spark, but no fuel.
could be bad fuel pump, or bad temp sensor.
- 99 2.8 Won't start. Cranks but doesnt start. Low or nonexistent fuel pressure.
- 2000 audi s4 automatic dash reads depress clutch to start wont start, car cranks but
- 96 A4 Quattro V6, no start, started to idle and accell rough now wont start
- Usual rough start and occasional good start
- audi 200 dies, wont start, wait.... will start
