Help changing faulty Heater/Cooler fan?
Old Sep 24, 2004 | 12:14 PM
JohnL's Avatar
Default Help changing faulty Heater/Cooler fan?
Hi,
The Heater/Cooler fan on my A4 (1998 model, with continuously variable fan speed) has started to become really noisy - sounds like a bearing on the fan has gone. Sometimes it works, sometimes it doesn't. Anyone know how easy it is to put a new one in? It sounds like the fan is located somewhere behind, or at least close to, the glovebox (my car is in the UK, so Right Hand Drive).
Any help/advice gratefully received.
John
Old Sep 24, 2004 | 04:38 PM
Jestnomen's Avatar
6th Gear
Default RE: Help changing faulty Heater/Cooler fan?
I tried searching a little for your problem, but I came up empty handed on a solution. I'm sure it's not going to be an easy task to undertake.
Old Sep 24, 2004 | 04:42 PM
Marcus's Avatar
Lots of parts removal for that one....not a simple repair....
Old Oct 15, 2006 | 08:43 PM
doublek661's Avatar
The heater fan is behind the glove compartment. I live in the uk and having problems with my fan intermitent fault. To remove glove compart there is a screw on the right hand side of the glove compartment (inside glove compartment). Remove side panel to the left of console, the passenger door shuts up against it. Remove screws, and finally one screw at the top of glove compartment. Fan will be visible, the remainder of screws are visible and easy to remove.
Dustinxiii
Nov 18, 2019 09:08 PM
e30bmw318is
Dec 9, 2009 04:00 PM
jzobie
Sep 25, 2008 02:14 AM
10SecS4
Jul 27, 2006 07:35 AM
quattrojan
May 25, 2005 05:01 PM
