HELP ME A4 problem!!!
Old Jun 21, 2010 | 01:43 PM
dsaw22's Avatar
Default HELP ME A4 problem!!!
i have a 97 audi a4 1.8t i just moved down to alabama from michigan and when i went to fill my car up on E when i started me car up it started sluggish and my check engine light came on. From this i thought i knocked something loose in my gas tank and plugged up my my fuel filter changed that no luck. I had a test ran saying i had a cylynder misfire so the i went and changed all of my plugs and still no luck then while my car was running i disconnected each coil pack to see what coil was bad doing this i found out that my 2nd coil was not reacting at alll changed that coil and still no connection so i brought the new coil back so now im thinking it might be my ignition mudule that is not working. Any suggestions?
Old Jun 21, 2010 | 02:32 PM
supermophed's Avatar
Did you pull the code for the check engine light?
Old Jun 21, 2010 | 02:55 PM
dsaw22's Avatar
no they never gave me the code i was in a big hurry at the time all he told me was i had a cylynder misfire but i know its my second cylynder because when i disconnect the the coil the engine doesnt idle down
Christopher Nemitz
Mar 12, 2012 09:02 PM
jimc137
Mar 9, 2011 06:48 PM
spyrosg7
Apr 4, 2010 07:48 PM
RIA6
Nov 30, 2006 09:06 PM
