Help me figure out what the problem with my car........
Old Aug 10, 2005 | 01:29 AM
dudley doright's Avatar
Default Help me figure out what the problem with my car........
I got these codes off my VAG COM and I did checked with my service manual what it meant. Did anyone run into this codes before and how did you fixed it?
17087 Brake switch B circuit malfunction
P0703 35-10 intermittent
16395 Camshaft Pos. Actuator Circ. Bank 2 malfunction
16717 Knock sensor 2 circ. high input
16955 Cruise/Brake switch (a) circ. malfunction
17536 Long term fuel trim mult. bank 2 system too lean intermittent - This could be a leak hose or some sort.
anybody has an idea?
Old Aug 10, 2005 | 01:34 AM
a4autocrossr's Avatar
Default RE: Help me figure out what the problem with my car........
i can tell you this..from lookng at the last one..and the one thats 2 above it...you need a new 02 sensor...just had that happen to me....as ofr the otthers..cant help
--E
Old Aug 10, 2005 | 01:46 AM
ORIGINAL: a4autocrossr
--E
Which O2 sensor did you replaced?
Old Aug 15, 2005 | 12:11 PM
Autocrosser,
Please answer the question I posted earlier.
BUMP
Old Aug 15, 2005 | 10:24 PM
david9999's Avatar
17536
Long Term Fuel Trim mult., Bank1
System too Lean 1)
2 Dcy
- Check Heated Oxygen Sensor (HO2S) -G39- (bank 1, sensor 1) and O2S control Page 24-22
- Check Oxygen Sensor (O2S) behind Three Way Catalytic Converter (TWC) -G130- (bank 1, sensor 2) and O2S control Page 24-42
- Check fuel pressure, fuel pressure regulator and residual fuel pressure Page 24-111
- Check fuel injectors Page 24-102 and Output Diagnostic Test Mode (DTM) Page 01-51
- Check EVAP canister purge regulator valve output Diagnostic Test Mode (DTM), Page 01-51
16955
Brake light switch -F-
Implausible signal
- Check brake light switch and brake pedal switch Page 24-177
tties4me
Jul 3, 2014 08:12 PM
jaimea6
Oct 3, 2009 09:50 PM
kevsaudi
Jan 1, 2008 08:32 PM
kronic budz
Oct 1, 2007 03:14 PM
