HELP ME PLEASE!!!
Old Aug 2, 2006 | 05:41 PM
techbod's Avatar
Default RE: HELP ME PLEASE!!!
line the left up with the right ( notice the holes are larger on one side they point at each other
[IMG]local://upfiles/12092/A379949D470F403EA1340644926B7B5F.jpg[/IMG]
Old Aug 2, 2006 | 05:43 PM
acetrebo's Avatar
Avant, does he need to check the crankshaft as well?
Do you know where the marks are for the crank?
techbod's Avatar
also line the bottom end up of course
Old Aug 2, 2006 | 05:44 PM
techbod's Avatar
see you think like me but your faster at answering
ORIGINAL: acetrebo
Old Aug 2, 2006 | 06:06 PM
acetrebo's Avatar
yes, but where are the markings for this on the 2.8? Do you have a bently handy?
My guess would be on the pulley and cover like mine was, just wanted confirmation.
Trey25's Avatar
rotate the cam twice and line it back up, put the belt on and rotate the crank a few times to make sure internals aren't touching.
Old Aug 2, 2006 | 06:14 PM
klum00's Avatar
when you say rotate the cam, can i just rotate that left pulley with my hands?? the crankshaft is good the marks on that are lined up.
Old Aug 2, 2006 | 06:19 PM
  #18
techbod's Avatar
lower timing mark TDC
[IMG]local://upfiles/12092/21E0D739184C4DE48635A066BDD97B94.jpg[/IMG]
Old Aug 2, 2006 | 06:22 PM
  #19
techbod's Avatar
it seems all you need do is rotate the left side but check every thing is lined up
Old Aug 2, 2006 | 06:29 PM
  #20
klum00's Avatar
ok so i got the cams lined up, put the belt on and then rotated the crankshaft a couple times. it rotated fine, but i noticed that i didnt have the same resistance all the way around, at some points it was a little bit easier to turn than others. is this normal or do i need to take the belt off and try again?
