HELP !!! - Oil Light Flashing
Old May 18, 2006 | 03:48 AM
michal's Avatar
Member
Default RE: HELP !!! - Oil Light Flashing
check for debris in oil pan ( pluged oil pump) oil pump (oil sendimg unit) faulty?
do the flush always helps at around 200k
Old May 18, 2006 | 03:57 AM
MrGreek's Avatar
How much work is it to get to the oil pump??? Do they have to take the whole front facia of the car apart much like replacing the timing belt? If thats the case I may just do that as well.
Thanks for all the advice so far guys...........!!!!
Old May 18, 2006 | 11:19 AM
north5995's Avatar
By the book its 3.5hours just to drop the oil pan. There is a lot of **** you have to do to get in there apparently. Get an Auto RX flush done and replace the pump and associated piping as those could be filled with sludge and buildup. Don't drive your car like Jeff said - you could cause more damage.
zzr
Nov 9, 2009 05:55 AM
blanthony
Mar 25, 2006 01:18 PM
