help tire wont come off!!! flat tire.....
Old Nov 24, 2005 | 04:49 PM
soccrstar's Avatar
Default RE: help tire wont come off!!! flat tire.....
nobody picked up
guess they closed :-(
Old Nov 25, 2005 | 12:50 AM
YFZFourFifty's Avatar
I'm guessing your absolutely not mechanically proven AT ALLLL.... or your just a girl...
A breaker bar is a long handle for a socket wrench that doesn't twist it has a really long handle so you dont have to exert as much force as a regurlar short socket wrench... if you push enough it will eventually unscrew... Put your muscles into it.. or if you are a teenager or somthing.. ask your dad to help you!
Old Nov 25, 2005 | 01:03 AM
StevenTownsend's Avatar
use force :]
Old Nov 25, 2005 | 02:53 AM
mjvss21's Avatar
yea use a torque wrench and it should come off there is no way to exert enough force with a small ratchet
Old Nov 25, 2005 | 06:08 AM
bhj0887's Avatar
I broke 3 studs with a breaker bar and a 3 ft pipe. Mine were really corroded on there.
Old Nov 25, 2005 | 02:19 PM
dudley doright's Avatar
Are you turning the wrench counter clockwise? I can't imagine why you are having a problem removing the lug bolt. It is only tightened at 80 ft-lbs, unless it is not the one that came with the car and you have different thread pattern.
Let us know what happened.
Old Nov 25, 2005 | 05:12 PM
tealetm's Avatar
Just make sure when you're trying to losen it that the car is not jacked up... obviously. Be careful when using a breaker bar- a greater moment is applied when your lenthen the lever by a few inches- try not to shear the stud! As for you guys recommending hitting the rim with a hammer to get a stuck wheel off, I had a buddy try that once from under the car and he almost got crushed because the car wasn't situated on the jack properly. Try soaking the **** out of it with PB blast or a similar penetration fluid (watch overspray on brakes...)
shanritz
Nov 26, 2007 10:04 PM
shanritz
Nov 26, 2007 06:17 PM
akoby9
May 1, 2007 12:11 AM
Cameron
Jan 30, 2007 04:26 AM
west2005
Jan 12, 2007 09:18 PM
