Help, turbos overboosting
Old Jan 16, 2006 | 03:52 AM
jimbooos's Avatar
Default Help, turbos overboosting
I bought a 2001 a4 in July, it ran for a month then the timing belt skipped some teeth and it was dead. It turned out the previous owner uped the timing and welded the tensioner for the timing belt in place, they also rewired the car so their aftermarket turbo would take it to the max. Now after replacing the head, a couple cylinders, having the car wired correctly, and replacing the cat, the aftermarket turbo keeps overboosting and cutting out. What can i do to make the turbo and engine work together again?
Old Jan 16, 2006 | 03:53 AM
PandaXpress's Avatar
Default RE: Help, turbos overboosting
but turbo are u running and wut tuning
Old Jan 16, 2006 | 04:53 AM
Jeff's Avatar
Zombie Defense Force
what kind of boost controller are u running? n75, mbc or what?
Old Jan 16, 2006 | 05:49 AM
tip5's Avatar
Damn perfect reason why to buy a completely stock car and mod yourself.
Old Jan 16, 2006 | 06:26 AM
SilverSeven's Avatar
Just put on a fuel cut defender and big injectors and it won't be overboosting anymore. Well ok, you won't call it overboosting anymore, you'll call it loads of fun.
Old Jan 16, 2006 | 10:19 AM
dafrazi's Avatar
Need more info. What PandaXpress said.
Old Jan 16, 2006 | 04:11 PM
FASTER's Avatar
Tech Slut
overboosting? sounds like fun. j/k. what kind of ecu do you run?
Old Jan 17, 2006 | 05:38 AM
jimbooos's Avatar
how do i find out if its a n75 or mbc when i bought the car i thought it was stock
Old Jan 17, 2006 | 11:59 AM
quattrosedan's Avatar
heh...dejavoo...(if thats how you spell it??) I had the same problem when I bought my car. The only reason I got it was because I got it for so cheap. I ended up posting some pics of the turbo....guys on here helped me to decide what it was...then I contacted atp to find out what I could do.....turned out nicely....
Old Jan 17, 2006 | 02:10 PM
clconversion's Avatar
well first I would find out what turbo is in it and what software it has a MBC will help you out but in the long run you are going to run into more problems if it is not tuned right
Jaggz
Nov 18, 2014 02:30 AM
quattroforthewin
Oct 6, 2010 08:51 AM
TheQuattro
Oct 23, 2005 09:54 PM
Infamous
Jun 27, 2005 04:27 PM
Infamous
Jun 20, 2005 06:52 PM
