Help! Window problems and it's raining!
Old May 28, 2007 | 11:39 PM
97blackA4's Avatar
Default Help! Window problems and it's raining!
97A4. Window bashed in by vandals then replaced by pro installer. Now it goes up part way then back down. I have to pull it up by hand. Is this a fit issue or a bad motor or regulator? Thanks.
Old May 28, 2007 | 11:41 PM
18T's Avatar
18T
Default RE: Help! Window problems and it's raining!
i think its the motor. put it up and turn the car off.
Old May 28, 2007 | 11:43 PM
01A4T's Avatar
does it go up most of the way then all of a sudden go down when you hold the window up switch?
Old May 28, 2007 | 11:44 PM
01A4T's Avatar
if it does, then just tap up on the switch and it will go up. you just have to tap, then let go, tap and let go...... till it's up
Old Jun 1, 2007 | 03:53 PM
97blackA4's Avatar
I'll try that tonight. But this is a new problem. It started after the break-in. Any ideas on fixing it? The speed of the window is very, very slow going up, but regular speed going down.
Old Jun 2, 2007 | 12:34 AM
acetrebo's Avatar
Take it back to the pro installer, and have them fix it.
Sounds like the regulator is still not right.
Old Jun 2, 2007 | 12:39 AM
aRIf's Avatar
what do you mean why going down ?
you know our windows system comes with security. if you apply pressure on the windows while it's going up, then it goes down for safety. maybe something putting pressure on window or something that's why it's going down. just a tought.
h4x0r
Dec 31, 2011 12:20 PM
goodh20
Sep 5, 2009 04:48 PM
meatbiscuit
Dec 1, 2007 09:19 AM
EVOLA4
Oct 26, 2007 08:20 PM
auDi1.8TQ
May 15, 2005 05:04 AM
