HELP_Speedo Whacky-Can't Read CODES
Old Nov 21, 2006 | 10:03 PM
Dhenkel's Avatar
Default HELP_Speedo Whacky-Can't Read CODES
My wifes 99 A4 had her speedometer needle go whacky today,it was bouncing all over the place.Anyone no what will cause this?Also I am unable to connect my OBD scanner to the car.It will powere the scanner up but won't reconize the car or connect?????I have a regular cheap scanner that I have used before and a Snap On and neither one works???Help Please and thanks for the assistance.Dave
Old Nov 22, 2006 | 02:50 PM
dozentrio's Avatar
Default RE: HELP_Speedo Whacky-Can't Read CODES
My speedo won't move at all, checked codes and it looks like it could be the vehicle speed sensor (VSS). Which, if you go back a page or so, people have told me is located on top of the tranny, near the 02 sensor held on by a 10mm bolt. Pretty cheap to replace if that's your problem...
Old Nov 22, 2006 | 03:29 PM
smokeU's Avatar
ORIGINAL: Dhenkel
Old Nov 22, 2006 | 04:44 PM
techbod's Avatar
what cartridge are you using the the snap on tool have you used it on that car before?? same with the other tool have you used it on that car before?? the VSS could be a good starting point or you have a shorted wire somewhere not allowing you to probe the system
old 5k0ol
Aug 28, 2012 06:39 PM
Tilts-a4
Apr 1, 2012 06:51 PM
kairo77
Oct 14, 2007 06:04 PM
lbyron859
Jan 31, 2007 05:08 AM
cary12
Mar 21, 2006 12:07 AM
