Got my codes read, can someone explain?
Old Mar 18, 2006 | 05:09 PM
cary12's Avatar
Default Got my codes read, can someone explain?
I went to Advanced and got my codes read. It was only one code which made me a little more relaxed. The code is P0441. They guy told me that it could be from not tightening the gas cap tight enough or from some bad fuel? I told him that the light has been on for a while and that I disconnected the battery but the light came back on. He told me that disconnecting the battery doesn't completely clear the code. He cleared it for me and said it shouldn't come back on.
Is what he said true? Are there any other factors that could have made the light come on? It didn't come on while I was driving home which is good. When I disconnected the battery, it came on the minute I pulled out of the drive way.
Any help would be great. I was going to take it to get the scheduled maintenance done and I didn't want them to give me some BS. I feel much better than I did. The car is running great.
Old Mar 18, 2006 | 05:13 PM
cary12's Avatar
Default RE: Got my codes read, can someone explain?
Here is the code verbage...
P0441 - EVAP Emmission Control System Malfunction
Thanks again for any help!
Old Mar 18, 2006 | 08:41 PM
cary12's Avatar
I think the problem might be a bad seal on the gas cap. I just picked up a new gas cap and will replace it when I fill up again.
Am I talking to myself?
Old Mar 18, 2006 | 11:52 PM
kakarot's Avatar
EVAP is a valve near air filter. fuel at diferent station next time.
Old Mar 19, 2006 | 12:54 AM
cary12's Avatar
I'm going to start using QT for good. I have been filling up at different stations for a while now with no luck. I drove all day without the light coming back on which is a good sign. If it comes on again, I guess I'll have to bend over and lube up for the mechanic... I'm praying it doesn't come back!
Old Mar 19, 2006 | 01:32 AM
avanttripleloop's Avatar
correct term is evap emissions control system,incorrect purge flow.just because there are 5 other evap emis control system codes.any chevron gas there,sounds like purge valve may be a little sticky.
Old Mar 19, 2006 | 01:56 PM
cary12's Avatar
ORIGINAL: avanttripleloop
Is bad gas the only thing that could cause the CEL for this code to come on? I'm just hoping it's nothing serious. The light hasn't come back on.
Old Mar 19, 2006 | 02:21 PM
i don't think it is bad gas.i think it is purge valve acting up and could go soon.nothing serious now but if you get an 0455 you will know the purge valve has failed.
Old Mar 20, 2006 | 04:59 AM
AudiSimmo's Avatar
what car you got?
Old Mar 21, 2006 | 12:07 AM
cary12's Avatar
ORIGINAL: AudiSimmo
what car you got?
It's a 2001 A6 4.2 Quattro. Any other help would be great.
A4 Beast
Jun 15, 2014 01:14 PM
Tilts-a4
Apr 1, 2012 06:51 PM
Bodferret
Feb 17, 2008 08:23 AM
kairo77
Oct 14, 2007 06:04 PM
lbyron859
Jan 31, 2007 05:08 AM
