Hey Guys. Noob Here. Need URGENT help. Which A4 to BUY. Details Inside :)
Old Oct 5, 2011 | 03:44 PM
tm33's Avatar
Default Hey Guys. Noob Here. Need URGENT help. Which A4 to BUY. Details Inside :)
Hey guys, Well in about 2 hours I'm flying to LA to pick up 1 of the 2 following cars. The problem is I'm not sure which would be better. I need some advice
I'm mostly just looking for the best value. They both have been taken care of pretty well. The only problem with the 2004 is it got in a crash in 2006. Seller says "Cosmetic damage. Side doors got hit and replaced by approved auto body shop through insurance. No frame damage"
2002 A4 Quattro 3.0
85K Miles
$8,400
or
2004 A4 1.8 Quattro
64K Miles
$10,500
Carfax and Pictures below. Thanks SO much!
2004 Audi
09/13/2004
5,261
Vehicle serviced
03/28/2005
Vehicle serviced
10/19/2005
Recommended maintenance performed
Washed/detailed
02/28/2006
Vehicle serviced
05/23/2006
Seatbelt buckle replaced
Maintenance inspection completed
Seat or seat upholstery repaired
Headlight assembly replaced
Headlight bulb(s) replaced
12/20/2006
Amplifier/sub-woofer installed
Brake light bulb(s) replaced
Washed/detailed
Exterior light bulb(s) replaced
Tail light assembly replaced
License lamp assembly replaced
• Police accident reports are required in California when the estimated damage exceeds $750. The date of this particular accident was not reported to CARFAX, but it likely occurred between Jan. 2006 and Jan. 2007.
05/22/2007
Washed/detailed
Radio replaced
Lighter replaced/repaired
Console repaired
07/13/2007
Headlight switch replaced
Washed/detailed
Door handle replaced
12/31/2007
Anti-theft/keyless remote battery replaced
Front wiper blades/refills replaced
Brake fluid flushed/changed
Washed/detailed
03/12/2008 37,010
Front suspension serviced
Washed/detailed
04/15/2008 38,350
Washed/detailed
08/01/2008 40,853
Washed/detailed
02/28/2009 45,422 Pacific Audi
Oil and filter changed chassis lubricated
09/19/2009 50,292 Pacific Audi
Washed/detailed
01/23/2010 52,701 Pacific Audi
Ignition coil(s) replaced
04/02/2010 53,942 California
Inspection Station
06/19/2010 55,250 Circle Imports
Vehicle serviced
11/10/2010 58,190 Downtown Audi
Vehicle serviced
12/04/2010 58,480 Pacific Audi
Brakes checked
02/22/2011 60,003 Pacific Audi
Tire condition and pressure checked
05/07/2011 60,990 Circle Imports
09/03/2011 63,918 Midas
Brakes replaced
09/17/2011 64,107 Pacific Audi
Inspection completed
2002 Audi A4
09/15/2003 19,083
Passed emissions inspection
09/25/2003 19,104
Engine checked
09/28/2003 19,138 California
Irvine, CA Title issued or updated
Registration updated when owner moved
the vehicle to a new location
02/26/2004 22,558
Rear bumper fascia replaced
Engine/powertrain computer/module checked
08/06/2004 26,931
Fluid levels checked
12/09/2004 30,940
Cup holder replaced
06/08/2005
Front exhaust pipe replaced
Tail light bulb(s) replaced
Headlight assembly
Horn replaced
Front bumper fascia replaced
Tires rotated
10/31/2006
Rear brake pads replaced and rotors resurfaced
12/19/2007 61,073
Vehicle serviced
08/30/2008 65,164 California
Inspection Station
Irvine, CA Passed emissions inspection
03/17/2009 69,370
Vehicle serviced
11/13/2009 73,550
Front brake pads replaced
12/21/2009 74,250
09/06/2010 78,301
07/27/2011 84,561
Battery/charging system checked
Brakes checked
08/03/2011
Duplicate title issued
Owner 4
Purchased: 2011
09/09/2011
New owner reported
Old Oct 5, 2011 | 04:46 PM
02A6Beau's Avatar
both of them look pretty clean. appears that they were well cared for. not too concerned about the accident damage. seems that it was repaired properly. biggest difference I see is the '02 has the 3.0 V6 and the '04 has the 1.8T (4 cylinder). The 1.8T is going to be pretty under powered, stock but has the most modding/go fast potential. The 3.0 is going to be more of a stately cruiser. Not much you can to to make it go faster.
The most important thing I see is the neither car has had the timing service done (I didn't see it on the maintenance records anyway). The 1.8T is much easier to work on. Timing service at an indy shop should be ~$800. The 3.0 is the biggest PITA engine to work on EVAR! ~$1200 for the timing service. Both are considerably more expensive if you have the work done at a dealership. (prices are approximate. just using those numbers to give you an idea). The '04 can probably go for a while before needing the timing service but will definitely need to be done sooner rather than later. The '02 will probably be alright for a short time but the mileage is starting to get into the "worrisome" range.
just some things to think about
-not an expert. just an enthusiast
Old Oct 5, 2011 | 04:58 PM
tm33's Avatar
Perfect response. Appreciate it man!
Old Oct 6, 2011 | 04:21 PM
MKE_Audi's Avatar
+1^
Only other thing I didn't see is the trans in each vehicle.
I would prefer a manual trans and it will be less costly to repair than an automatic trans.
And if it is a manual trans you need to watch that t-belt service window a little closer. With a manual we put a lot more stress on that belt during 'spirited' driving. I did mine at 93k in a 1.8t quattro manual and the belt was cracking at each tooth. Helped a buddy with his 1.8t from a passat (same year, 90k) but it was an automatic and tbelt looked in much better condition. Was the first tbelt service for both vehicles.
Good luck and enjoy!
sombra13
Oct 31, 2011 03:26 PM
sempaipaul
Jan 20, 2008 11:36 AM
Smitty2
Apr 21, 2007 08:00 PM
