hiding the chip
Old Mar 8, 2006 | 11:57 PM
kmill58's Avatar
Default hiding the chip
can i hide the chip from the dealership with my vag-com?
Old Mar 9, 2006 | 12:01 AM
Jestnomen's Avatar
6th Gear
Default RE: hiding the chip
What chip do you have? What year is your car? No a VAG-COM can't "hide" it.
Old Mar 9, 2006 | 01:30 AM
StepUpProductions's Avatar
if you have APR you should be able to turn it off it you have it setup to do so with your cruise control
Old Mar 9, 2006 | 01:38 AM
cary12's Avatar
I didn't think the stealership could tell if you had a chip?
Old Mar 9, 2006 | 01:41 AM
only if they testdrive it im pretty sure... i could be wrong
Old Mar 9, 2006 | 01:56 AM
SeaWolfxix's Avatar
Here's something from AWE tuning and the GIAC chips:
"Dealership / Warranty issues: A majority of dealerships are wary of performance products. By installing a "stock chip module" your vehicle is electronically indistinguishable from a stock vehicle. (Dealerships do not commonly open the ECU, but it is possible to see the modifications within the ECU.)"
Apparently with their system, you can have a stock chip and a performance chip. The stock chip isn't noticed by the dealer's electronic stuff, but if they open it up, they can obviously see the chip/modifications.
I'm not sure about your chip maufacturer, though.
Old Mar 9, 2006 | 04:28 AM
Jeff's Avatar
Zombie Defense Force
i dont think the dealership will look unless u pay them and arm and a leg to
Old Mar 9, 2006 | 12:00 PM
VitaminB6's Avatar
APR software is also not detectable electronically. If you've gotten the chipped and stock programs, you can revert to the stock program using the cruise control stalk (you definitely tell a chipped K03 from a stock one with a test drive). If you've bought the lockout option, you can lock out the other programs and disable the cruise stalk from being able to select programs (the dealer may of course be familiar with the ability to select via the cruise control and try to detect your chip that way). Ultimately they could just look at your DV and see that it's been upgraded and will know you're chipped anyways.
jerritt
B8 Models
Sep 17, 2012 09:33 PM
Desert Fox
Jul 22, 2010 12:13 PM
jeepguy88
Nov 29, 2007 12:26 AM
i3uddha
Oct 9, 2007 08:33 AM
SrK
Jan 21, 2005 03:08 AM
