HIDs installed!
thekyman, place the resisters in parallel to draw more current.
It origonally used 55 watts and now uses 35 watts. A 7 ohm
resistor that can handle 20 watts in parallel is needed.
ORIGINAL: CRAZYHAWK
Do I also install that on the side that isn't plugged into anthing now?
ORIGINAL: JETSPEED333
I [sm=smiley27.gif] HID
-might as well make a DIY if you can about the resistor... would probably be useful for others
All I know is that im not goign to deal with that darn signal light... worse case senario im going to switch over to the plug and play installation...
