Hoping new cat will fix problems.
Old Apr 12, 2007 | 08:38 AM
david9999's Avatar
Default RE: Hoping new cat will fix problems.
There still may be codes stored in there. Have them pulled at autozone and post them back here.
Old Apr 12, 2007 | 01:56 PM
2k S4's Avatar
ORIGINAL: khj677turbo
Well, the car back fires at open throttle and sometimes when i dont give it enough gas off the line, it just chokes and backfires. The car is completely unsmooth throught the rpm range when accelerating normally. Its like its bogging down, especially after about 3100 rpm or so it chokes and its constant. I havent checked for codes, but im lazy, and i need to drop the exhaust becasue there are vibration issues that i cant seem to fix from the hangers etc. My buddy before me ran a bov for a little on the car, as dumb as that is.
Sounds like you are running relay rich. Check the CTS, vacuum leak on the FPS, or a boost leak.
Read the dam codes.
Old Apr 12, 2007 | 02:18 PM
tooxtreme8813's Avatar
I'm 110% sure you have an issue with misfires, either bad coils or plugs I just had the same problem and same symptoms with no codes either
Old Apr 15, 2007 | 10:47 PM
khj677turbo's Avatar
Ok, finally got an answer at discount. It was free for them to check, but it took three different people to finally be able to read the code. It read, Knock sensor bank 2 code po332 . It was a hand held device and i dunno if this is causing the unsmooth rpms.
Old Apr 15, 2007 | 10:51 PM
CRAZYHAWK's Avatar
Run high octane fuel in it.
Old Apr 15, 2007 | 11:15 PM
why? lol, maybe an explanation would help
Old Apr 16, 2007 | 01:00 PM
CRAZYHAWK's Avatar
Clear the code and see if it comes back.
I recommend inexpensive things first.
A U D I
B7 Models
Jun 4, 2014 09:40 PM
Phylum
Sep 6, 2013 12:39 PM
daedaestoy
Dec 22, 2010 09:45 PM
hch1974
Jun 29, 2009 07:33 PM
a4autocrossr
Jul 18, 2006 04:42 PM
