How do I know if my control arms are going?
Old Nov 18, 2005 | 09:36 AM
JettaRedII's Avatar
Default RE: How do I know if my control arms are going?
ORIGINAL: Redgoat
Hope you get it sorted out.. let us know whats going on with it.. if it was the tie rods.. or if it was something else
Sorry it took so long to get back--I couldn't find this thread.
It turned out to be that my brake pads were paper thin and finally went. When they get that thin, they start to break loose and shift in the caliper when you put the brake on. The weird thing is I know I had checked them earlier and there was at least 3/16". Perhaps the calipers got locked open and wore them out faster than I could imagine.
Old Nov 26, 2005 | 05:29 AM
haveaseat's Avatar
Member
put the car up in the air and get urself a pry bar, place it between the bottom of the upper control arm and the tire and pry away and look for movement, just did the front left on my 01 a4 cuz of clunking when i went over bumps and such
Old Nov 26, 2005 | 03:42 PM
Soley4pres's Avatar
you did the front left? ....meaning you replaced your control arms or just pry'd at it with a pry bar? lol
Old Dec 19, 2005 | 10:24 PM
haveaseat's Avatar
Member
i did the pry bar thing and then i found that it was my control arms and replaced both upper control arms
Old Dec 19, 2005 | 11:06 PM
bhj0887's Avatar
To check the uppers, just jack up the car, and hit the top of the joint. There should be no play.
I just replaced my uppers becasue the joints had gone to ****.If it weren't for the seized pinch bolt, it would have only been a two hour job.
Old Nov 21, 2007 | 05:03 AM
SF8's Avatar
SF8
How much does a independent shop charge to
A) Replace uper control arms for a year 2000, A6front wheel drive.
B) Replace all pads and rotors for four tires.
Thanks,
Steve
Old Nov 21, 2007 | 09:17 AM
RaFa's Avatar
ORIGINAL: SF8
Thanks,
Steve
a local shop here in miami quoted me for control arm kits around $1200, if i brought the parts $450
and the same shop quoted me for replacing rotors and pads for $200 with I bringing the parts.
I just thought It was TOO much money! so I did them myself! still have to do the control arms on the bottom.....i did the upper control arms and the tie rod it was easy except the tie rod that was stuck.
the rotors and pads are pretty simple just search for DIY and you save alot of $
jdahlen24
Aug 25, 2011 09:50 PM
jdahlen24
Aug 25, 2011 03:05 PM
audiboy31790
Aug 20, 2008 11:07 PM
Tonyd
Aug 10, 2005 09:33 PM
Tonyd
Aug 9, 2005 01:02 AM
