how do you read the maf??
Old Jan 27, 2006 | 04:09 PM
y2karnival's Avatar
Banned
Default how do you read the maf??
just wondering when you vag the comp how can you tell if the maf is working properly. i have a 99 a4 and cant seem to get rid of code P0102 and code p1545..so if the maf is working right then i can only assume that the chipped giac ecu i got from someone isnt compatible with my car and should replace it with the stock one. is it harmful to drive with those codes? it seems that the car likes to stall when i come to a stop after getting on it abit, but then will drive ok if i dont really get on it. im bout ready to give up and put the factory ecu back in...agghhhhhh
Old Jan 27, 2006 | 04:39 PM
techbod's Avatar
Default RE: how do you read the maf??
1 of 2
[IMG]local://upfiles/12092/1478B12A2CEB444AAA89385BD78F2371.jpg[/IMG]
Old Jan 27, 2006 | 04:40 PM
techbod's Avatar
2 of 2
[IMG]local://upfiles/12092/966637AD428F475EA599BA81A47F2F6F.jpg[/IMG]
Old Jan 27, 2006 | 05:24 PM
y2karnival's Avatar
Banned
cant really see that too well but i think i get the idea. what should it be reading, so i know if its ok or needs to be replaced? if the cel code is saying low circ input wouldnt that entitle it is going bad?
Old Jan 28, 2006 | 10:25 AM
david9999's Avatar
If you just put in a chip, check to make sure that all the connections from the ECU to the wiring harness are tight.
Do you have access to a Vagcom?
Display fields
Display group 002: Air mass taken in with engine at idle and operating temperature
Display
xxx /min
xxx %
xx.x ms
xxx.x g/s
Indicated
Engine speed (RPM)
Load
mean injection time
Air mass
Specified value
FWD: 740 to 860 RPM
AWD: 800 to 920 RPM
15 to 33 %
1.0 to 4.0 ms
2.0 to 4.5 g/s
Note
If specified value is not obtained: Evaluation Page 24-63
kasaudi01
Nov 3, 2011 09:46 PM
poky43
Oct 15, 2008 12:57 AM
OutLaw A4
Dec 5, 2006 09:14 PM
bhj0887
Dec 22, 2005 01:21 AM
danny99
Nov 29, 2005 11:56 PM
