how the hell to install an amp
Old May 10, 2006 | 01:57 AM
wolfdog's Avatar
Default RE: how the hell to install an amp
I'm new to the forums but I've done a lot of reading and such so I don't do stupid things like asking about BoVs...
I found this site and think it may help you out (don't be thrown off by the sub thing...
http://www.a4mods.com/index.php?page...es/stereo.html
Old May 10, 2006 | 11:24 AM
north5995's Avatar
Use the search and check for my username. I posted about how to do this and did it about 3 months ago. I used the DIYs on audiworld.com.
Old May 9, 2011 | 04:39 PM
mykel69's Avatar
Default Remote wire! Which one is the remote wire?
Originally Posted by lbraasch
it's not hard. you just have to understand how these things work. they're a lot like bmw stereos...
head unit is just the reciever. amp is in the trunk. meaning... you already have a preamp out coming from the deck to the trunk. - need line level output for amps - check
all speakers in a bose system are 2 ohms. so, i fyou want to change all your speakers, you'll have to run a different amp, or lose a lot of power, b/c you'll only draw aprox. 50% of the wattage w/ 4ohm speakers (and most are 8ohms anyways). running a new amp also requires running new speaker wires. takes patience, but also not an incredible feat.
amp's require a power cable. tap the battery. nothing new. a lot of people go through the grommit where the fues box is on the driver side. peep audiworld tech articles for help... - amp power - check.
amps require remote turn on. since audi already has it's own amp, you can borrow the remote turnon signal, thus, you have your remote wire - remote wire - check.
amps require ground. ground it to the trunk. - amp gorund - check.
so we have pre-amp out, remote power, actual power, ground, and speaker wire. what's left? nothing. it's not hard, it just is a little different than the jap import cars.
I have an '05 a6 and have had my multimeter all over the trunk looking and simply cannot find a switching 12volt wire to turn my amp on. I read somewhere that the switch cuts on via relays, I dunno and can't seem to find out anywhere! HELP!
Jimbezy
Mar 4, 2008 01:13 PM
Brandon2000s4
Oct 18, 2007 12:24 AM
outinfront
Oct 17, 2007 04:59 PM
