HOW MUCH EXTRA POWER CAN THE 1.8 BLOCK HOLD???
Old Feb 13, 2007 | 04:47 AM
sean1.8t's Avatar
Default RE: HOW MUCH EXTRA POWER CAN THE 1.8 BLOCK HOLD???
ORIGINAL: onepoint8tee
No, dont go 400hp on stock internals, thats like engine suicide.
actually it's not. i know many people running that power right now on stock internals and it is fine. Arif would be one of them. the 71r elim will max out at ~400bhp. however, if you rev that power at high rpms for a very long extended time you might melt a piston or perhaps snap a rod..
and the pistons are forged but the rods are not. all you have to do is drop in some rods, clean up the pistons and you'll be good to go for up to ~500bhp and probably a 8k redline
Old Feb 13, 2007 | 04:50 AM
sean1.8t's Avatar
ORIGINAL: Lazer Viking
boost about 30 psi on stock internals
~30psi on what turbo? psi rating it not a generic figure. a ko3 and a GT35r flowing at ~30psi will have very different results
ORIGINAL: Dj Spiel
at what point would u change manifold BT?
i have no idea what you just said
Old Feb 13, 2007 | 04:52 AM
sean1.8t's Avatar
ORIGINAL: BaconBait
Closer to 350. Jeff dyno'd 337 awhp. Most people that get numbers that high usually end up with a rod or 2 through the block.
his carwas/is a freak of nature
Old Feb 13, 2007 | 04:53 AM
Dj Spiel's Avatar
basically I was asking at one point would "one" change the manifold------- big turbo setup?
ORIGINAL: sean1.8t
ORIGINAL: Dj Spiel
Old Feb 13, 2007 | 04:56 AM
onepoint8tee's Avatar
ORIGINAL: sean1.8t
the last dyno arif had maxed out at about 297 whp. When you are BTing a B5- which will typically have mid to higher mileage, its pretty smart to do internals if you are exceeding 300hp and want it to be as reliable as it is effective.
ORIGINAL: Dj Spiel
what?
Old Feb 13, 2007 | 04:58 AM
Dj Spiel's Avatar
http://www.ecodetuning.com/shop/cart...tail&p=529
Old Feb 13, 2007 | 05:00 AM
  #18
sean1.8t's Avatar
well you can only keep the stock manifold if you have either a ko3, ko4, or one of the 3 eliminator setups.. due to the flow restriction of the stock manifold it is recomended to change it out to the almost identical ATP product even if you're going ko4. but especially if you go with an eliminator turbo.. other than that if you change out the turbo to anything else, I.E. t28, full GT28rs, GT30r, etc.. you have to upgrade it.. ATP makes a decent one(most popular one)that is affordable but puts the turbo in a horrible position. there is a cast unit out but i can't think of the name of the company at this point. then there is a Full-Race manifold. pricey but oh so worth it!!
  #19
???? Still dont understand what youre talking about...
That manifold is a major pita to bolt on btw.
Old Feb 13, 2007 | 05:05 AM
  #20
Dj Spiel's Avatar
yeah question answered---sorry should of rearranged words
ORIGINAL: sean1.8t
