how much whp should i have
Dude, if you want me to admit it, then fine. I'm wrong. You're talking a technicality on the flange; I'm talking about a brand name on a B6 with problems, regardless of the flange used.
I don't see many going with other flanges on that kit on a B6. For as little number of APR kits on the other forums for B6, I don't know of one running a t3 or t25 flange ATP manifold. So, maybe that kit linked above is the one that works perfect. I've never actually seen it on a B6.
But the manifold crack posts I linked to (I didn't even look at them to know, but I'll take your word for it) are guys running K04 (so yeah, stock flange), GT28R or GT71R turbos, regardless of the flange. Those are the most common kits, and those are the manifolds that are cracking. They aren't just stock manifolds re-using a K03s. They are ATP manifolds, running big (well, bigger) turbos, and they crack. So I'm wrong in how you word it; I'm right in that ATP manifolds on a B6 crack.
[align=left] [/align]
All the links are for elim turbos, thus stock replacement manifolds. The two manifolds are completly differnt and the flanges are nowhere close to the same location.
You know someone with a ATP kit, he is on here and zine....sean18t, he has the kit and has no problems on his b6.
You really should compare the manifolds and see the difference.Also in the future,check your sources before using them as "proof".
ORIGINAL: fahquad
[align=left][/align]
the ATP STOCK PLACEMENT KO3 FLANGED manifolds crack like probably no other aftermarket manifold on the market. that is nothing new..
but the ATP T25/T3 LOG manifold does not crack any more than APR's or Treadstone's. it has it's issues, but every single manifold that isn't a tubular manifoldwill. unless they use a turbo brace. which is what do you know, something that the ko3 has so the STOCK manifold doesn't crack.
Conceded. No biggy; I didn't check link to see the kit wasn't an eliminator kit. I mistook CincyTT's post as saying ATP manifolds as a whole don't crack. I wasn't concerned with what the flange was. If I'd have looked at the link on the kit and not just assumed it was an eliminator kit that 99% of the B6 owners have, I'd have known better. We were arguing two different points. I was arguing ATP as a whole, and you (CincyTT) were arguing the flange making a difference. You, are right based on numbers, because there just aren't enough B6 owners with that flange in a kit to say otherwise on my part. Sorry.
Even still, APR has not had one return on a inconel Stage 3+ manifold in their existence. They don't have problems with the manifold. So, that's still a bar set real high. Software is another story.
No more littering with misinformation on my part; I'll leave that up to everyone else now.
ORIGINAL: cincyTT
[sm=WTFsgign.gif] Where is this cracking coming from? They are cast and far from fragile. ATP manifolds are often hard to install, but far from cracking. Also, using a GOOD tuner (Revo or Unitronics), and not MIKA pos "tune", you have nothing to worry about. So stop with the BS
Your original post is how I interpreted it, and I admit I really didn't read much after that as I jumped on the defensive from that post. So I said I was wrong. So be proud. You're right. And a dick. Winning combination. You'll help many a B6'r destroy their car, I'm sure.
ORIGINAL: fahquad
Dont be mad that i can read and know what the hell is going on. Again, funny with the me not knowing anything jokes. Its not like im building my engine right now andstrokingit to just over 2L. But im sure if i talked you about that, it would be over your head.
