Hydraulic lifter noise
Old Sep 28, 2004 | 11:22 AM
dudley doright's Avatar
Default RE: Hydraulic lifter noise
What brand of motor flush do you recommend? Is that the one where you add a litre of it in the crankcase and run the car for 5 minutes?
Old Sep 28, 2004 | 07:44 PM
CRAZYHAWK's Avatar
The list contained Mobil 1 0W-40 European Car Formula.
Old Sep 28, 2004 | 10:41 PM
David_K's Avatar
Yeah chriz? how many miles were on your car when you did this flush? did you have any leaking problems afterward? And doose what exactly does auto tranny fluid in the oil do
Old Sep 29, 2004 | 04:29 AM
SlimChriz's Avatar
ATF has a lot of detergents in it so it scrubs the goo
I had about 85K the first time I did it, first oil change I did on the car and black goo instead of oil came out. the second time I did it (91K) the oil darkened alot but not like the first time
Im not sure the brand but yes it said put it in the engine when its warm then let the engine idle at 2000rpm for five minutes by holding the gas down then drain..
Old Sep 30, 2004 | 06:10 PM
Doose,
Any symptoms that you could share with us for suspected problem?
HEC
B8 Models
Mar 5, 2014 01:40 PM
kwathom1
Aug 10, 2009 07:53 AM
Wicked Jester
Mar 7, 2008 06:37 PM
brrman
Mar 21, 2007 06:42 AM
frankinstyn
Mar 20, 2007 02:13 PM
