I am hearing a 'wwwwrrrrr' sound on my back driver side wheel
Old Aug 7, 2007 | 11:02 AM
boundn20's Avatar
Default I am hearing a 'wwwwrrrrr' sound on my back driver side wheel
I am hearing a 'wwwwrrrrr' sound on my back driver side wheel. (sounds like a ruff snow tire, but a lot more noticeable) at first i thought it was just a worn tire (the back tires are pretty worn, while the front are in good shape) so i tried rotating the tires, just to see if that was the prob, and its not. Even w/ the alsmot new tires in the back, it makes the sound. also it goes away when i am making a left hand turn?. . . any suggestions on what it could be?. . could it just be an alignment is needed? bearing?. . anything quick i can check b/f bringing it to a shop? . any advice would be appriciated.
Thanks
Old Aug 7, 2007 | 11:27 AM
whatevamann's Avatar
Default RE: I am hearing a 'wwwwrrrrr' sound on my back driver side wheel
Its your wheel bearing for sure.. I hadd the same thing... a loud humming and high vibration.. almost made me deaf. On my rear driver side. I brought it to my tire guy, he said it was feathering of the tire.. so I rotated my tires.. same thing... so i brought it to my dealer... they found out it was my wheel bearing.
Old Aug 7, 2007 | 12:13 PM
boundn20's Avatar
did you replace your own?... ive never replaced one b/f but is it a job thats easy enough to do yourself?. . any special tools needed?
Old Aug 7, 2007 | 02:55 PM
clconversion's Avatar
it has to be pressed in not really a diy job unless you have access to a press
Old Aug 7, 2007 | 03:31 PM
boundn20's Avatar
i do work at a place w/ a small shop that does have a smaller press.. not hydrolic, but i wouldn't imagine you would need that much. Any good diy guides on how to do it?
morpheous
Jun 14, 2012 03:11 AM
Lance Kragenbrink
Mar 25, 2010 07:32 PM
NachoWayne
Jul 29, 2008 04:53 AM
boundn20
Aug 30, 2007 09:25 PM
austindgarner
Mar 27, 2007 11:05 PM
