'wwwwrrrrrrr' sound on back driver side ?
Old Aug 7, 2007 | 10:59 AM
boundn20's Avatar
Default 'wwwwrrrrrrr' sound on back driver side ?
I am hearing a 'wwwwrrrrr' sound on my back driver side wheel. (sounds like a ruff snow tire, but a lot more noticeable) at first i thought it was just a worn tire (the back tires are pretty worn, while the front are in good shape) so i tried rotating the tires, just to see if that was the prob, and its not. Even w/ the alsmot new tires in the back, it makes the sound. also it goes away when i am making a left hand turn?. . . any suggestions on what it could be?. . could it just be an alignment is needed? bearing?. . anything quick i can check b/f bringing it to a shop? . any advice would be appriciated.
Thanks
Old Aug 7, 2007 | 12:00 PM
GeilKyle2's Avatar
Default RE: 'wwwwrrrrrrr' sound on back driver side ?
Deffinatly sounds like a wheel bearing
Old Aug 7, 2007 | 12:14 PM
boundn20's Avatar
ive never replaced one b/f but is it a job thats easy enough to do yourself?. . any special tools needed?
Old Aug 7, 2007 | 09:33 PM
SAudi's Avatar
wheel bearing. the most special tool i can think of is a press to get he new bearing in.
Old Aug 9, 2007 | 07:14 AM
CRAZYHAWK's Avatar
Rear left wheel bearing. Find an independent shop to replace it for $250.
Old Aug 9, 2007 | 11:45 AM
GeilKyle2's Avatar
I've normally seen 170ish at most of the independent shops around here.
Old Aug 30, 2007 | 09:25 PM
Cracktout's Avatar
if you feel confident enuf, pull it off yourself and bring it to a napa autoparts store and they will press it out and the new one in for about 40$. Goof luck
Lance Kragenbrink
Mar 25, 2010 07:32 PM
saintforlife
Dec 20, 2008 10:34 AM
NachoWayne
Jul 29, 2008 04:53 AM
mudpuppu_94
Dec 11, 2006 01:46 AM
