Wet Floor in front and back Driver's side?
Old Jun 5, 2008 | 09:11 PM
NachoWayne's Avatar
Default Wet Floor in front and back Driver's side?
While driving during a significant rainstorm yesterday I later found that the floor of my front and backseat on the drivers side was soaking wet????? I determined that it was not a door leak, and no water was visible anywhere else inside the car. Could clogged sunroof drains be the problem? Or may it be something else under the car??
2000 1.8 A4 Avant
Old Jun 5, 2008 | 11:15 PM
Tweaked's Avatar
Default RE: Wet Floor in front and back Driver's side?
Clean the crap out of your cowl drains where the battery sits.
Old Jun 6, 2008 | 03:23 PM
johnnythefox's Avatar
yeah...when i bought my a4 the gasket underneath the ecu box was bad, and water leaked into my driver's side front and rear footwellstoo so i would check that also
Old Jun 6, 2008 | 03:39 PM
kriptonik's Avatar
Do you have aftermarket stereo installed?
Old Jun 7, 2008 | 04:21 PM
NachoWayne's Avatar
no, everything is stock.
Old Jul 28, 2008 | 08:21 PM
sammypoodle03053's Avatar
I am having the same issue. What is an ECU and where it?
Old Jul 28, 2008 | 08:22 PM
I am having the same issue. What is an ECU and where it? Thank you
Old Jul 28, 2008 | 10:05 PM
Tweaked's Avatar
The ECU or ECM is the engine control unit or module. It is located beneath the area of the windshield cowl on the driver's side, under the black cover. It is contained in the "waterbox," which is a sealed black box protecting the ECM from the elements.
Now, what is your issue? Do you have water in the cowl or the cabin? What is your concern with the ECM?
Old Jul 29, 2008 | 04:53 AM
chaos92287's Avatar
99% of the time its the sunroof drain plug. its located at the back of the engine bay on the drivers side, all the way in the corner. which is also right next to the ecu
Jeresh
Jun 25, 2015 10:06 PM
morpheous
Aug 2, 2010 08:44 AM
Lance Kragenbrink
Mar 25, 2010 07:32 PM
boundn20
Aug 30, 2007 09:25 PM
mudpuppu_94
Dec 11, 2006 01:46 AM
