i blew it this time. wat do i do now
Old Dec 20, 2006 | 05:25 PM
FLEX_rs's Avatar
Default i blew it this time. wat do i do now
ok, i was planning to upgarde the front suspension on my b6, i got round to undoing the bolt that clamps the two ball jonins that are at the top of the strut which are connected by an arm to the upper mount of the suspension. i accidently snapped the head of the bolt, will i be able to knock it out, if i cant wat do i do.
Old Dec 20, 2006 | 05:29 PM
techbod's Avatar
Default RE: i blew it this time. wat do i do now
so its only a broken bolt use the proper tool called a ball joint splitter so you wont damage the threads and the rubber boot
Old Dec 20, 2006 | 05:33 PM
FLEX_rs's Avatar
i overexagurated so i can get some replies , the bolt is stuck in the clamp andthe ball joints wontrelease until the bolt is loosened, i thought about drilling through it
Old Dec 20, 2006 | 06:02 PM
gotaudi's Avatar
This happened to me on my 1997 A4. I tried everything: tapping it out, heating it, PB blaster, drench in liquid wrench and sea foam let it sit for a day and a half, it still was stuck in their. My last resort was to drill it out my advice start with a small drill bit and work your way up. Be careful because you do not want to drill the part of the controll arm.
Try everything else before you drill it out use as your last resort
Good luck
Old Dec 20, 2006 | 06:11 PM
techbod's Avatar
ORIGINAL: FLEX_rs
please don't over exaggerate the wrong answer will be given to your problem, you will probably need the ball joint splitter otherwise you might need to replace the complete unit if you use a hammer, you could put another nut on there and try to hammer it to break it free
Old Dec 20, 2006 | 06:14 PM
FLEX_rs's Avatar
is the bolt threaded all the way through, i guess it would be easyer to knock out if it isnt
Old Dec 20, 2006 | 06:20 PM
gotaudi's Avatar
No I dont think it is threaded all the way through. Mine on the 1997 wasn't but it was totally seized and had to drill it, it was frustrating as all hell
Old Dec 20, 2006 | 06:31 PM
FLEX_rs's Avatar
how did u drill it through, did you take the complete assemply off or just try to drill sideways
Old Dec 20, 2006 | 06:37 PM
gotaudi's Avatar
Try to knock it out with a hammer first then drill. what I did was I turned the wheel to the side so I had more room. I startes with a small drill bit and worked my way up till I could take out the bolt. If you are going to drill cover everything up first you do not want metal shavings on you brakes or ABS sensors.
Good Luck
Old Dec 20, 2006 | 06:41 PM
techbod's Avatar
Default RE: i blew it this time. Wat do i do now
the ball joint splitter is very cheap some pictures might help
