I NEED HELP..I CANT TAKE OF MY OIL FILTER NEED HELP
Old Feb 20, 2007 | 08:07 PM
LuCiAnO02A4's Avatar
Default I NEED HELP..I CANT TAKE OF MY OIL FILTER NEED HELP
I AM CHANGING MY OIL... THE FILTER IS NOT COMING OFF...3.0 A4 ANY SUGGESTIONS LET ME KNOW I AM WAITING
Old Feb 20, 2007 | 08:44 PM
JETSPEED333's Avatar
SoCal Crew Member
Default RE: I NEED HELP..I CANT TAKE OF MY OIL FILTER NEED HELP
what tools are you using?
Old Feb 20, 2007 | 08:45 PM
2k S4's Avatar
Right tight, left loose
If it's more then hand tight, you will need an oil filter strap wrench, or use some water pump pliers & crush the end to turn.
If all else fails, and your ghetto, take a LONG screwdriver, and put it threw the end then turn.
Old Feb 20, 2007 | 08:56 PM
i just gave up, i broke 2 filter wrench trying to get it out...this is unbelievable its dark now so i have to wrestle it again in the morning...that screw driver idea seems like what i am going to do...at least this way i can poke a hole throught it AND KILL IT[:@][:@]
Old Feb 20, 2007 | 09:00 PM
wood_e's Avatar
Strap wrenches are worthless... get a claw type at wal mart for $3. Worked llike a charm when I was in a pinch.
Old Feb 20, 2007 | 09:30 PM
AbsoluteGTR's Avatar
I agree get the claw type first.
DO NOT resort to using a screwdriver. It is one of the dumbest thing too do. If it already broke two wrenches then a screw driver will just shred the metal housing apart and then you are ROYALLY screwed. I have worked on a car before where just the oil pump metal plate was attached to the oil filter housing. the guy had put a screw driver through it and totally annihilated the filter. Not smart.
Also make sure you are turning counter-clockwise
Old Feb 20, 2007 | 09:54 PM
soo...sounds like just by a claw wrench and go from there...that exactly what i am going to do..if it doesnt come out again i am just going to burn the car...hell no.. i cant afford that..THANK YOU EVERYONE FOR YOUR INPUT
Old Feb 20, 2007 | 10:15 PM
Karl's Avatar
easiest thing to do..
take a screw driver and a hammer, pound the screw driver into the side of the oil filter.. this will allow the grip and torque you need to get it off. Of course this can create a mess so make sure that you have a few rags readily available.. also make sure you take the new filter and apply a subtle amount of oil to the rubber gasket on the top of the new filter.
Old Feb 20, 2007 | 11:25 PM
qUaTtRoA4's Avatar
^+1, I have done that more than a few times, it definately gets the job done, I'd say it's the easiest way, when you find that you can't turn the filter...gl!
A4 Jed
Jun 23, 2013 06:13 PM
elburko91
Mar 22, 2011 07:27 PM
Niclipse
Feb 9, 2009 01:39 AM
ironman
Apr 16, 2007 03:53 PM
