I need help! Vag
Old Jan 3, 2006 | 06:25 PM
turbo's Avatar
Default I need help! Vag
Address 01: Engine
Controller: 8E0 909 518 F
Component: 1.8L R4/5VT 0001
Coding: 0016751
Shop #: WSC 80182
5 Faults Found:
17700 - Map Controlled Engine Cooling Thermostat (F265): Open Circuit
P1292 - 004 - No Signal/Communication - Intermittent
17938 - Camshaft Timing Adjustment: Short to Ground
P1530 - 002 - Lower Limit Exceeded - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 001 - Upper Limit Exceeded
16685 - Cylinder 1: Misfire Detected
P0301 - 001 - Upper Limit Exceeded
16687 - Cylinder 3: Misfire Detected
P0303 - 001 - Upper Limit Exceeded
Readiness: 0000 0001
Eney Ideas of what I need to fix?
I had a coil pack pop off last friday now the check engine light is on and the car is running like crap.
The car is a 1.8T B6
Old Jan 3, 2006 | 06:48 PM
GraffixWB's Avatar
Default RE: I need help! Vag
get those codes cleared and see what you get !!
Old Jan 3, 2006 | 06:52 PM
onepoint8tee's Avatar
Coil packs dont just pop off.. Sounds like it broke?
Old Jan 3, 2006 | 06:54 PM
turbo's Avatar
They do if your plugs are not tight
Old Jan 3, 2006 | 07:26 PM
ORIGINAL: turbo
No.. The coil pack wouldnt be able to screw down all the way onto the valve cover if the spark plug was out of the socket.. Have you taken the time to actually look at it, unsrew things and check
Old Jan 3, 2006 | 07:30 PM
turbo's Avatar
I have a b6 the coil packs only push on not screw down
turbo's Avatar
Ok I cleard all codes and after a short drive this poped up on the vag.
Address 01: Engine
Coding: 0016751
Shop #: WSC 80182
2 Faults Found:
16686 - Cylinder 2: Misfire Detected
P0302 - 001 - Upper Limit Exceeded
Readiness: 0000 1101
Do you think this is just a bad coil pack?
The thing is that this is the pack that poped off last friday.
Old Jan 3, 2006 | 08:41 PM
AudiTech04's Avatar
Try swapping coils to see if the misfire moves
Old Jan 3, 2006 | 08:52 PM
turbo's Avatar
I moved all the coil packs now I am geting a missfire on #1 #2 and#3 !!!!! WTF!
