I need help! Vag
Address 01: Engine
Controller: 8E0 909 518 F
Component: 1.8L R4/5VT 0001
Coding: 0016751
Shop #: WSC 80182
5 Faults Found:
17700 - Map Controlled Engine Cooling Thermostat (F265): Open Circuit
P1292 - 004 - No Signal/Communication - Intermittent
17938 - Camshaft Timing Adjustment: Short to Ground
P1530 - 002 - Lower Limit Exceeded - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 001 - Upper Limit Exceeded
16685 - Cylinder 1: Misfire Detected
P0301 - 001 - Upper Limit Exceeded
16687 - Cylinder 3: Misfire Detected
P0303 - 001 - Upper Limit Exceeded
Readiness: 0000 0001
Eney Ideas of what I need to fix?
I had a coil pack pop off last friday now the check engine light is on and the car is running like crap.
The car is a 1.8T B6
Coding: 0016751
Shop #: WSC 80182
5 Faults Found:
ORIGINAL: turbo
They do if your plugs are not tight
Ok I cleard all codes and after a short drive this poped up on the vag.
Address 01: Engine
Coding: 0016751
Shop #: WSC 80182
2 Faults Found:
16686 - Cylinder 2: Misfire Detected
P0302 - 001 - Upper Limit Exceeded
Readiness: 0000 1101
Do you think this is just a bad coil pack?
The thing is that this is the pack that poped off last friday.
Address 01: Engine
Coding: 0016751
Shop #: WSC 80182
2 Faults Found:
