Sponsored by:
Sponsored by:
Idle control
Old 10-01-2004, 08:43 PM
gregp1962's Avatar
Default Idle control
Sometimes, my 1.8t has a hard time idling after coming to a stop. It seems to act like the idle control valve is bad. But, in looking at it, it doesn't look like it has one. What would be the cause of this?
Old 10-01-2004, 09:33 PM
Jestnomen's Avatar
6th Gear
Default RE: Idle control
I thought only the V6 had an ICV.
Things to check:
Vacuum hoses (replace them if they are looking cracked or dry).
MAF sensor
Leaks around MAF housing
Get new sparkplugs
Do a throttle body adaption
VAG your car
Old 10-01-2004, 10:32 PM
Does it do the RPM "bounce"? if so its just your computer relearning your car. its perfectly normal and will returnn to normal in a day
Old 10-01-2004, 11:21 PM
Jestnomen's Avatar
6th Gear
He said "sometimes", which leads me to believe it is a cronic problem. But you are correct, the idle will bounce while the ECU is adapting (~100 miles) after a battery disconnect.
88A5TQ
12-02-2009 05:33 PM
nrf1211
10-10-2008 02:15 AM
motorrad
09-27-2008 08:11 PM
brightside06
09-15-2007 04:00 PM
GT5 S
01-31-2007 01:16 PM
Quick Reply: Idle control
