idle prob still cant figure out.
Old Jan 4, 2008 | 08:43 AM
oettinger1919's Avatar
SoCal Crew Member
Default idle prob still cant figure out.
Well my engine has been idling really rough and sometimes it wont fire, all this since i put my carbonio intake on. I did pull a codes for cyl. 1/3/4 and there was also a "Multiple engine misfire" code but i think that may have come from seafoaming the car and letting too much in to the manifold. I have tried cleaning out the MAF and also i checked the intakes fitting just to make sure it wasnt leaking anywhere letting junk into the engine or something and came up with nothing. Im not getting any CEL when the car doesnt fire or it idles like crap. My shop told me that they would have no where to look until the CEL comes on(idiots.) So im stuck now and i have nothing to go off of, i know that theres many posts now about this problem but the difference is it seems to have something to do with the intake and it now happens more frequently and i can tell its getting worse but it happens at such random times. The engine can be bone cold or just driven several miles. I go to turn it on again and it wont fire. sometimes it idles really high for several seconds or it doesnt get up past 700rpm's
Old Jan 4, 2008 | 10:36 AM
hiwords's Avatar
Default RE: idle prob still cant figure out.
did you clean the throttle body? swap out the cts too
Old Jan 4, 2008 | 10:43 AM
SoCal Crew Member
Is is safe to remove the throtte body to clean it? i dont want to throw anything off, whats the cts?
Old Jan 4, 2008 | 10:46 AM
hiwords's Avatar
you dont' have to remove it. there's a intake/throttle body cleaner that you just spray and it'll clean it. CTS= coolant temp sensor. it can cause weird problems that are hard to diagnose because it will send weird signals to the ecu when it's screwed up.
Old Jan 4, 2008 | 10:47 AM
SoCal Crew Member
oh ok i get it. Is that around the reservoir?
Old Jan 4, 2008 | 04:43 PM
ImTheDevil's Avatar
There's a coolant temp sensor swap DIY writeup on either AudiDIY.com or AudiWorld.com - one of the two has it and it's detailed pretty well.
Old Jan 4, 2008 | 05:34 PM
CoastalA4's Avatar
I'd try swapping back to the OEM intake setup just to confirm that it's indeed your new intake that's the problem. It does exhibit symptoms of a dirty TB or bad CTS. But, unless you got some debris caught in the TB while during the intake change, it would be hard to emphatically say those were bad if it ran good with the old intake.
Old Jan 5, 2008 | 09:11 AM
seanko04's Avatar
Yeah go back to your stock box then see if the problem arises again.
Old Jan 5, 2008 | 10:02 AM
ImTheDevil's Avatar
You guys thinking maybe the oil from the filter is freaking out the MAF? Not a bad idea.
justinclarke
Nov 25, 2010 04:03 PM
jason955
Oct 18, 2009 11:10 PM
sljone
May 24, 2007 09:15 AM
karguy427
Oct 26, 2004 07:04 PM
