Idling problem with 1999 A42.8Q.
Old Nov 9, 2004 | 05:22 PM
stquattro's Avatar
Default Idling problem with 1999 A42.8Q.
A4 2.8Q 30v Man.
Need some friendly advice.
the car is ok when driving from cold but once fully warmed up and idling at traffic lights the engine revs start to fluctuate and as a result cause car to idle rough. the plugs are new and have been using superplus unleaded, i thought it may be the fuel filter but that made no difference. Any suggestions ?
Old Nov 9, 2004 | 05:39 PM
Jestnomen's Avatar
6th Gear
Default RE: Idling problem with 1999 A42.8Q.
clean the throttle body out, they tend to get filled with sludge from the egr.
Old Nov 9, 2004 | 05:54 PM
stquattro's Avatar
would the garage have to carry this out?
Old Nov 9, 2004 | 06:31 PM
brrman's Avatar
Could be your plugs. Whens the last time you changed em?
If you clean your TB, use throttle body cleaner and not carb cleaner. Might want to get a new gasket for it also.
Old Nov 9, 2004 | 06:45 PM
Jestnomen's Avatar
6th Gear
Nah i've cleaned mine out myself, and as Brrman said, you will need a new gasket. You can probably find some instructions on Audiworld.com.
ToughlilT
Feb 24, 2015 07:52 AM
iggys6
Feb 7, 2014 04:55 PM
logic
May 4, 2010 01:11 AM
NRogge
May 15, 2008 11:30 PM
HansBlix
Sep 15, 2006 12:37 AM
