Ignition and Key problem
Old Mar 31, 2006 | 08:27 PM
BraMas's Avatar
Default Ignition and Key problem
Since we bought our 98 A4 back in Feb. we have had trouble with the key not feeling like it is the right key for the ignition. When you put either key we have in it will not turn it feels just like we have the wrong key in. But if you wiggle it around a little it finally will turn but this week it has gotten worse. The previous owner told us about the problem and said they had the ignition replaced but it still did the same thing. Is this a common problem or do we maybe have bad cut keys.
Old Apr 1, 2006 | 02:45 AM
BraMas's Avatar
Default RE: Ignition and Key problem
SO I'm gonna assume this is not normal because I have had no responses.
Old Apr 1, 2006 | 05:02 PM
david9999's Avatar
Not common, but ignition switches to break or wear out.
Old Apr 1, 2006 | 05:08 PM
avanttripleloop's Avatar
steering wheel interlock.try moving wheel slightly to left or right and turn key
Old Apr 1, 2006 | 11:37 PM
dankhound's Avatar
If the keys are new and still have sharper edges try running them thru the wire wheel. Sometimes brand new keys stick if they arent "cleaned up" before use.
Old Apr 2, 2006 | 12:49 AM
BraMas's Avatar
I have tried that and it still wont move sometimes. I was just hoping someone knew of a common problem so I didn't have to take it to the stealership. Oh well thanks anyway.
ORIGINAL: avanttripleloop
Jace2010
May 19, 2010 04:08 PM
persephone76
Aug 29, 2009 08:49 PM
VThmoney
Aug 10, 2009 05:29 PM
audijawns
Nov 28, 2005 05:18 PM
yellowa4
Aug 7, 2005 12:18 AM
