Sponsored by:
Sponsored by:
Ignition Module Resistance Test
Old 12-13-2007, 04:28 PM
Honda882000's Avatar
Default RE: Ignition Module Resistance Test
Is there any way to test the signal to the output stage from the ecu? Can I use the 5 pin connector for that?
  #22
Old 12-13-2007, 04:46 PM
Checking ignition system[/align]Testing twin-spark ignition system with two ignition coils[/align]Ignition coils and output stage form a joint component.
This component cannot be tested by conventional measurement media/methods.
If there is a fault in the ignition system:
‒Check power supply ‒Checking activation of power output stages
If no faults are found in the process of tests, but no ignition spark is produced:
‒Replace the output stage together with the ignition coils. [/ul]
Checking power supply
‒Unplug connectors on ignition coils.
=> Overview of fitting locations -‒→ Connect the multimeter (voltage measurement range) to contact 4a and to earth.
‒Switch the ignition on.
Specification: approx. battery voltage [/ul]
If the specification is not obtained:
‒Check the wiring. [/ul]
=> "Current Flow Diagrams, Electrical Fault Finding and Fitting Locations" binder
Checking actuation of power output stages
‒Pull the connectors off all four injectors. [/ul]
Note:
It is important to ensure that no fuel is injected during the test, as this would damage the catalytic converter. Therefore, the connectors on the injectors must be unplugged.
=> Overview of fitting locations -‒Switch the ignition on. [/ul]
‒→ Connect the V.A.G 1527 diode test lamp to the following contacts on the connector:
‒Operate the starter for a few seconds. [/ul]
3-pin connector on the wiring harness contact
Specification
1 + earth
Diode test lamp should
15 + earth
flash (brief impulse)
If the specified values are not obtained:
‒Switch off ignition.
‒Connect test box V.A.G 1598/22 to wiring harness for engine control unit
[/ul]
The following wiring connections should be checked for open circuits and/or short to positive or negative.
Test box V.A.G 1598/22, socket
15
71
‒Rectify any open/short circuit as necessary. [/ul]
[IMG]local://upfiles/12092/A7A449AB03EB4B92A832ADC5686599CA.jpg[/IMG]
  #23
Old 12-27-2007, 10:30 PM
Issue fixed! It ended up being the ignition module:-)
cathie98
03-24-2015 05:11 PM
Parrot head
10-12-2014 08:44 PM
stang32
02-23-2014 10:53 AM
gironhe
05-08-2009 03:18 PM
georger
11-17-2008 06:08 PM
Quick Reply: Ignition Module Resistance Test
