Ignition VAG-COM codes
Old May 11, 2007 | 09:19 PM
A4Tuner.'s Avatar
Default Ignition VAG-COM codes
Can someone please tell me what is up with these codes!
ive tried to find information on them on the interent, but havnt had any luck with them.
does anyone know what can cause these, possable causes, possable solutions, and definitions, please.
Thanks
P1393 / 17801[/b]
Ignition Coil Power Output Stage 1: Electrical Malfunction[/b]
[/b]
P1394 / 17802[/b]
Ignition Coil Power Output Stage 2: Electrical Malfunction[/b]
[/b]
P1395 / 17803[/b]
Ignition Coil Power Output Stage 3: Electrical Malfunction[/b]
i have also done a ICM test which is in another post.
Old May 11, 2007 | 09:48 PM
david9999's Avatar
Default RE: Ignition VAG-COM codes
Hopefully it is bad connections. Check that the wires are clean. Otherwise it is a bad ECU.
Old May 11, 2007 | 09:50 PM
david9999's Avatar
Hopefully it is bad connections. Check that theconnections to Otherwise it is a ignition coil output stage
Old May 11, 2007 | 10:25 PM
A4Tuner.'s Avatar
where is this though? ICM, spark plugwires or coils?
also, does stage 1 corrispond to coil 1 or L1/E1 on the ICM
stage 2 corrispond to coil 2, L2/E2 on the ICM ect?
I dont feel any misfire while im driving.
it hasnt got a rough or gumpy idle either.
i only thing i have noticed is that the car will slightly vibrate once i hit 60mph.
so, this isnt a major thing but im just after some information on them codes.
markymarc
Sep 8, 2010 01:59 AM
joenelson7687
Aug 25, 2010 04:10 AM
Jits7
Jan 25, 2008 06:46 PM
banderson121
Mar 17, 2007 05:36 PM
