im also doing my timing belt today
Old Jun 11, 2005 | 03:32 PM
ecksman's Avatar
Default im also doing my timing belt today
ok , i went and bought all the parts from the dealer except the water pump and the accessory belt, im ******* mad at myself for not getting it but its too late now, i think i read somewhere that u can change the pump without taking off the belt is that true?
Old Jun 11, 2005 | 05:31 PM
TomRitt's Avatar
Default RE: im also doing my timing belt today
False, the belt has a sprocket on the water pump iirc
Old Jun 11, 2005 | 05:32 PM
BFlan2001's Avatar
woah woah woah, ecksman, what year is your car? if you have a 00+ you'll be ok...if not, you NEED to replace your water pump with your tb, or you WILL be doing the whole job over again when the water pump fails.
Old Jun 11, 2005 | 05:46 PM
CRAZYHAWK's Avatar
My 2001 has the timing belt drive the water pump.
Old Jun 11, 2005 | 05:56 PM
BFlan2001's Avatar
ooops, my bad...again.
if you DON'T have a 00+, you'll be ok. the older models are external. i believe in 2000 they changed it
Old Jun 11, 2005 | 09:15 PM
oscar_3's Avatar
is it the same deal for a B6 timing belt as a B5?...replace after around 60-70k?
Old Jun 11, 2005 | 09:34 PM
david9999's Avatar
Actually, it was the early B5 that were the problem. The timing belt tensioner, not the belt would fail. Howver,k if there is no ensoin on the belt, it would slip, timing off, end of engine.
Still, I get worried past 80K miles, and I found that I was losing sleep wondering when it might go.
My previous toyota was a non-interference engine. I went over 200K miles on my second belt before I got rid of the car at 320K miles.
Audiguruforyou
Sep 20, 2011 01:31 AM
taifighter
Aug 20, 2008 12:22 PM
skidplatexa4
Jun 11, 2005 04:14 PM
