I'm getting so sick of working on my car...
Old Nov 29, 2006 | 10:32 PM
a4r6's Avatar
Default I'm getting so sick of working on my car...
Can anyone help me..
I just replaced my fuel filter... JUST.... Went to start it.. Nothing... Just turns over and over and over and over.. So I thought hmm.. Maybe it needs to prime.. Turned the key on turned the key off a couple times. The car started...
I get in to back it into the garage.. Touch the gas.. Car shuts off.. Wont run... Turns over.. .Acts like its out of gas... but its not....
stu
Old Nov 29, 2006 | 10:55 PM
onepoint8tee's Avatar
Default RE: I'm getting so sick of working on my car...
did you install the fuel filter in the right direction?
Old Nov 29, 2006 | 11:02 PM
a4r6's Avatar
No offence but its impossible to mess that up.. They are two different size bolts on each side..
Old Nov 29, 2006 | 11:03 PM
wood_e's Avatar
You sure the fuel pump is running? Check the fuse...
a4r6's Avatar
.. I can look it up, but you wouldn't happen to know what fuse that is off hand.
Old Nov 29, 2006 | 11:11 PM
a4r6's Avatar
Checked the Fuse.. Its fine.. Anyone know how to drop the tank.. Maybe I pulled a hose off
Old Nov 29, 2006 | 11:21 PM
ORIGINAL: a4r6
None taken. For fwd there are equal sized nipples on each side of the filter, and no where did you indicate in your post or in your signature that you are either quattro or fwd. What exactly made you think the fuel filter needed replaced anyway? Did you have this or other running issues before you replaced it?
Why do you have "control arms" in your signature btw???
Old Nov 29, 2006 | 11:56 PM
wood_e's Avatar
Maybe he was due for mileage... My olf fuel filter was NASTY...
a4r6's Avatar
First of all yeah.. Mine is a quattro... You should change your fuel filter in any Gasoline cars atleast every 20,000 miles.. I do it at 15.... Just habit... You're car is only as good as you take care of it.. I put control arms in my sig. because I bought the full febi kit from ecs... When I put it on it made a world of difference in the way my car felt and performed... When I have my 18's on it is amazing... I'm back to the stock sport 99.5 16's right now.. PS got the car to run.. No clue what happened. just turned right over and started ran a little ruff then ran after a 5 min drive and park/start... Thank you anyways guys...
Old Nov 30, 2006 | 12:03 AM
ORIGINAL: a4r6
Cool. Every 20k miles is excessive, but whatever makes you feel good. You probably just had some air in the fuel lines from when you removed your old filter. When I changed mine I had to give it a few tries before it would stay running.
azzy28
Jan 29, 2012 11:03 AM
Emilgevor
Mar 24, 2009 11:10 AM
Anos
Dec 20, 2007 03:35 PM
SAudi
Jul 16, 2007 01:25 PM
apg96
Oct 19, 2005 09:09 PM
