i'm an idiot....someone help me with my keyless entry please...
Old May 21, 2005 | 02:48 AM
BFlan2001's Avatar
Default i'm an idiot....someone help me with my keyless entry please...
i attempted to install an aftermarket keyless entry system in my a4...and the write-up i tried to use turned out to be completely worthless, so after a couple hours of screwing with all the wires, trying to make things work, i gave up...now i'm finally reinstalling my factory keyless entry.........but i cut the antenna.....[:@][:@][:@].....RIGHT at the base of the module too....is there anything i can do to salvage this thing????? can i splice the wires back together or is that not going to work in this case? i was thinking about taking apart the module and resoldering the wires inside there...any suggestions guys?
Old May 21, 2005 | 02:56 AM
jlaudio184's Avatar
Default RE: i'm an idiot....someone help me with my keyless entry please...
ouchie
Old May 21, 2005 | 03:03 AM
Jestnomen's Avatar
6th Gear
How do you have it wired up? Not sure if this is accurate:
http://forums.audiworld.com/a4/msgs/2113124.phtml
Old May 21, 2005 | 03:20 AM
BFlan2001's Avatar
maybe it's just me, but that list looks incomplete, only a few colors are included....the part that got me screwed up was wiring the relays in....i would consider myself to be fairly experienced with electrical systems, but i had at least 4 different wiring diagrams on hand and i still couldn't figure it out...a voltmeter would've helped...i even bought the exact same keyless entry system as the write-up, and it was supposed to be done on my exact car....
here's the write-up i used....imo it should be removed from their archives, but like i said, maybe i'm just being an idiot...
http://www.audiworld.com/tech/elec52.shtml
Old May 21, 2005 | 03:26 AM
BFlan2001's Avatar
i've pretty much given up on trying to get an aftermarket to work....unless someone tells me that i'm screwed since i cut my factory antenna....
Paul1234
Oct 18, 2012 10:43 PM
mab9981
Jul 29, 2009 01:40 PM
Figgy1682
Nov 21, 2007 11:40 AM
mark_2328
Aug 5, 2007 11:02 AM
Darthgeese
Jul 29, 2007 12:43 AM
